Yeah, I could not find anything similar to my build so I could get en idea how it will work together but I guess I will know soon enough.
Paul said to keep you away from it, said you will do the motor in and he will smash the box, what a couple of maniacs , haha
Doing you a favour. Everyone needs a OS88.
haha, we will see how you go with this new OS88 toy that you stuffed into your R, then you will look at the V-Cam and then maybe a Z_Cam or whatever comes next, just face it, you are a HOON!
Try being gentle with your shifts, coming last is OK :whistling:
Just have to love ya :wub:
No way. I need some sort of advantage with all you blokes and 3.0 + litres :D.
you have one.
Your 2.8 has less block material, and doesn't need an adapter for the sump.
All this equals weight saving :)
^^^^^ Too Much Red with lunch :whistling:
Last couple of days I think I have been celebrating after seeing some work being done on the car and just maybe, I might get it back in a week or so :yes:
:cheers: :cheers:
Oh I hope not.
Fark, I do not want to see this shit, lie to me, tell me stories of happy endings, just give me a week of blind, stupid delusional grandeur , please :yes: :yes: :yes: :yes:
Shit I was so pleased with the pics I hit the piss a little harder, well still hitting it, hic hic :cheers:
Pete your car will be ready tomorrow and exceed your expectations. This is true for one week. Enjoy.
Hi Daz, aint over until the fat lady sings, lol
When do you expect to be driving again ? What turbos are you getting ??
They said mine could be ready at the end of this week and if they keep going the way they were last week , this should be easy to do, BUT??????
Patients, no thanks. I am running out of life and need everything done ,yesterday :)
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
