The pressure on the valves is both sides, in and out, the exhaust manifold usually has more pressure then the inlet
Then that also has to do with how old and tired the springs are and what there seat pressure is
Who ever said there was no such thing as a dumb question is a dumbarse :yes:
Yes higher poundage inlet valve springs because you have boost pressure behind the inlet valves acting on the whole area of the backs of the valves . You don't have combustion pressure on the chamber side of them as soon as they close .
More boost means greater heat and pressure and the hot/exhaust side is the half to worry about to avoid reversions and detonation . A dedicated turbocharged race engine has to be reliable when running in a supercharged state for long periods of time . OE road turbo engines are designed to use the "power boost" to get up to speed or climb the odd hill for short periods of time .
Interesting actually , restricted rally engines are often thought to have small compressor sides compared to the turbine side . This is because they are rev limited by the restrictor so have no use for large compressor wheels . The turbines are big in relation to the compressor because they have to have a survivable pressure and heat balance across the engine ie hot side vs cold side .
To make any engine survive a lot of boost for any significant length of time you need to increase the flow capacity of the hot side . Things like porting/exhaust valve size/manifolds/turbos with larger hot sides eg GT3576R/very low restriction hot side .
Actual engine cooling is important because you have to reject more heat developed by higher power outputs . Effective oil cooling / charge cooling / water cooling would be a real good idea .
The burning question is how long do you expect to be using high boost performance ?
A .
  • Like 1
A .
^^ This.
Bolt that head down hard with some 625+ or L19's. And don't come crying if something lets go, it's bound to happen eventually. Even a popped cooler pipe makes a great mess at that pressure. :P
    • You'lll likely have to make do with R33 GTR for engine/tranny stuff, and Stagea for the body. I don't know that there's even been an actual diagram seen in the wild.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
