Itd be too much stuffing around trying to get AWD from a VQ35, you would just stick to the VQ25. Which is oh so original and exciting.
You know they made an awd vq35 stagea, yeah?
Love your work, seen many similar conversion start but never finish... but you seem to be smashing through all obstacles with great precision!
Down the track I hope you drop in the 4.5L crank and tickle the bores :)
Absolutely loved the series mate. I've been thinking for ages that a turbo V8 would be perfect in the Stagea. Good on ya for sticking with the manual box. It's gotta be a lot of fun. I must say the amount of detail in the series really drives home how much effort is required to do an engine swap like this. Bloody heaps! Damn awesome work. The workmanship looks second to none.
Why a VQ35 is the real question.
The VQ35 is an underrated engine. People didnt take to it for tuning the same way they did with an RB engine despite the fact that it actually lends itself to forced induction well. People using the HKS twin turbo kits are pushing around 400-450 rwhp on only 7psi of boost . The V series skyline was also used to test engine/drivetrain configurations during R&D for the R35 GTR. Ben did also say he wanted a nissan derived engine too, but that V8 was a good choice too
  • 7 months later...
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
    • I didn't actually try it at the time but a Launch X431 with the appropriate software licenses/upsell will have the ABS bleed function. The Consult II you can still find some old sets of equipment but they're really, really expensive:
    • Well I'll start by saying I'm not an engineer. I am going to go with the KiwiCNC ones.  They are made of 7050 alloy have good fillets and radius.  The material alone is in the order of double the strength and fatigue resistance - Those bolts, once torqued correctly place most of the load at the flat face of the mating surface - the 'stretch' you're talking about through torqueing them up would be far more than the extra stretch 'load' placed on them from a steering input or bump. (in my opinion) so I doubt they would flinch.    - but again "not an engineer".      oh and I don't think stitch welding 7050 is a good idea, likely just weaken the material (from what I read)
