:no: Some interestingly useless replies.
Lets start at the top. Your thread states you want it louder, yet in your post you want more power. Well a well designed exhaust may gain a few "nanowatts" but free-flowing exhausts on NA cars do not yield much gains vs turbo cars. NA cars need backpressure to make power.
IF you want to make the car slightly louder remove the resonator from the exhaust and weld a straight pipe back in, this will retain the stock muffler/s and will help you get noise/not power
Fail.
Cover your nose and mouth then go for a run, that's backpressure.
The term you're after is "scavenging effect".
OP, your question doesn't make sense. Without touching the exhaust you won't get more noise and power... Unless you go ITBs with trumpets.
  • Like 1
Fail.
Scavenging effect or more correctly exhaust gas velocity. Every engine want's as little back pressure as possible but NA's rely on scavenging more so the crossover of gas velocity vs lower back pressure is heavily in favor of gas velocity.
When i had my n/a r33, i got a cat back exhaust system for 100 bucks including canon, cat and hot dog reso. Car droned like a mofo, so i bought a adjustable 4 inch silencer from ebay, and had it partially opened. Worked like a charm, produced a nice tone with minimal to no loss of power. Im assuming the silencer created that "backpressure/increased velocity" that n/a's desperately desire. In fact, im pretty sure it became a little quicker, i started to pull (ever so slowly) on my mates n/a 34 after the exhaust "upgrade". Anyways im just talking from my past experience.
bullshit 100, i thought i'd have to fork out about 1k for a decent exhaust.
I would want it to also make my car sound better not just louder.
Did you get pulled over a lot before you got the silencer?
100 as stated will get you a shit exhaust which drones like a shit exhaust.
fitting a silencer (bottleneck) is not a good conter modification.
just get a decent exhaust proably a couple of hundred. and good headers maby another couple of hundred 2nd hand. maby 5-600 all up
after that just cam the thing
  • Like 1
camshaft.
the only way to make an engine give more killawasps in basic terms is increase the fuel and air intake and get the waste out.
with either forced induction which in not your option here
make it rev harder
or increase the capacity
Or don't bother and wait till you get a decent car.
I don't understand why people say this. I'm not able to get my full license for over 3 years. Out of p plate legal cars i got one of the best cars in terms of power for my restrictions. May as well improve it and learn as much as i can before i go for a turbo car.
camshaft.
make it rev harder
Camshaft makes the car rev at a higher rpm correct?
I've already got a k&n air filter. how do i increase air more than that? and not sure what mods will increase fuel flow.
increase capacity of power?
lol says like we don't understand.
The restrictions are nothing new. I too had to wait. I too got an N/A skyline.
The best thing i did to it was nothing. It was a car i liked the look of. Why waste cash on mods that will literally do nothing to improve the car? and just ask for more cop attention? Complete waste of cash.
Put said money that you are going to spend into a savings account. And come opens you will have a heap more to spend.
  • Like 3
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
    • Did some FASTing ...got the impression that the actual part# was a moot point ; seems all of these hardlines for coolant are discontinued/NLA... like, I take it you're after the hardline that bolts onto to the manifold...that's NLA according to amayama & nengun .... ...just to clear up some confusion, they typically mounted the AAC valve to the intake manifold somewhere near a coolant passage, so the body of the valve heats up & holds it open when engine's up to temp - no coolant flows through the valve, it's a mechanical, thermal connection.
    • And now the bloody flapper is jammed slightly open. Lazy as all f**k in 3rd-5th (very hard to convince it to make much boost before you run out of revs), but will make 12 psi in 1st, which shouldb't be possible with a 5 psi spring and controller set to <10 psi. Methinks I'm lucky it jammed where it did, rather than fully closed. It's actually a well weird situation. Careful examination of what's happening in the back of that housing when the gearbox comes out and all the other stuff (injectors, AFM retune) is supposed to be done, next week.
