Thanks guys for all the feedback overnight and PM's.
The reason for not going for 12 trigger points is some ECU's cannot keep up with the count, Yes I know with less if the count is lost it takes longer to regain the position however with only 6 points their is alot less chance of losing the count as the ecu can keep up.
Link G4 keeps up with 32
pretty impressive and informative - ta
Would be interested for RB26.
Having not looked into or thought about this, prior to this thread, is there any aftermarket kits available/recommended?
I'd like to support "murrayis" if made available for the RB26.
Ross do a crank trigger kit for RBs,
Includes balancer, sensor and trigger wheel..
Just need an available input for the ecu
I've got one, just need to make sure the sensor is positioned correctly
Thanks Joey
I'm sure I have read where a few peeps have gone the Ross Blancer and trigger and had issues.
Not blaming Ross as it maybe how it's set up. (throwing belts?)
Could be totally off the mark too :/
Yea Once I have everything sorted I'll do up a group buy. I've secured some machining prices from China... yes I know but it comes down to cost and have ordered some samples to check quality.
I've just started machining my set because I am impatient and it doesn't cost me anything :)
About 10 minutes in with close to 2 hours to go:
More progress pics to come.
theres a few around, one kit in qld(ONO 747 vl runs one)pics on this forum somewhere, one in vic(sticks sell them) and one in s.a just finished,
(pro gtr motorsport) plus ross,theres probally , no doubt theres others i don't know about
cheers
darren
Edited by jet_r31
The idea around my items is to be affordable for the DIY'er who can work around mounting them him/her self. The kit should work fine on all the dual cam RB series - As I only have a rb20 and a rb25 to test on this will confirm but I don't see many potential issues as they all use the same oil pump and cam gear sizes.
Thanks Joey
Yep I've heard of people throwing belts, I was making over 420rwkw and I only threw a belt once in over 10,000km of driving. Maybe installation issues? Not sure
Looks really good.
Ross one seems so expensive and ive never had an issue so never really considered it. This looks like it has a lot of potential. I could probably get the ross trigger wheel seen as I already have the balancer
Must be nice having that gear at your disposal. Id love to be able to make a CAD drawing and then just make it happen lol
It is great having toys to mess with to make little things that you can;t just buy. I converted my Mill to cnc over the past year and these are really the only full thing I have completed so far for a purpose.
Finally finished the Cam bracket just a little time ago. Didn't run through the finishing passes as these are just for me so the finish is rough :)
post-23119-0-98593900-1419921796_thumb.jpg post-23119-0-36655000-1419921799_thumb.jpg
I have the ross 32-2 teeth setup with the standard CAS for phasing
There are plenty of kits floating around the world ATM, but it is always good to see someone else's approach to this issue
You just use the input that would normally read the crank angle output from the factory CAS, it just has to be programable
I have thrown 3 Gates belts so far the last of which lasted less then 2 hours, fitted it drove to dyno then it couldn't take the power and decided to spread it self around the engine bay, I then had to drive the bastard home with no PS on 275/35/19 front tyres :(
Funny thing is I stopped at Autopro on my way home from work to get another belt or three but they only had there own elcheapo belt in that size and I needed to turn the car around so I grabbed it got home fitted it then went and got three Gates belts, well one full trackday and a spirited drive up putty and back plus a few thousand Ks later the elcheapo belt is still on there in perfect nick :/
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
