I regards to the 12 trigger wheel I was involved with some bench testing of a hall effect 24 tooth wheel as opposed to a 24 tooth using the stock cas optical sensor and concluded that the optical sensor was the issue rather than the 24 tooth resolution. We spun it up to 6000 rpm on a drill and rev synch captured on a motec, halech and microtech and notice a significantly cleaner signal and square waveform rather than the pyramiding pattern that we saw on the optical sensor. There were also no changes in edge order(skipping triggers). Using a 12 trigger would be no issue based on the observations as the 6000 rpm on the 24 wheel would he equivalent to spinning a 12 trigger wheel at 12000 rpm. Hope this helps.
This is the setup I've been running on my sohc 30 (we braced the bracket up after that pic). Ran a autronic 6-1 chopper disc in cas for cam sync. Went from not being able to rev past 4000, to revving out cleanly to 7. Plus just running smoother all round.
Currently building a 30neo, am I able to replace the disc in the Neo cas?post-78438-0-01277500-1419929375_thumb.jpg
I love seeing home grown innovation! Great work on having a crack at it Murrayis! If you do end up selling it I'm sure you'll sell a bucket load of them!
Huzqld whilst looking slightly agricultural I'm sure yours works perfect too, good job!
Now hurry up and get a kit on the market you blokes before I convince myself to buy the Ross kit @ $2000!
Ill have the first sample batch next week I hope.
Anyone wanting to support the project I can work out a special price for the first run :)
I'm hoping to get the per unit cost to around $90 so the brackets for $180 and sensors around $70 each then all youll need is the chopper wheel and wiring
Cheap cheap
Too cheap, mate you're more than entitled to add some intellectual property value into them, nobody should be expected to put the work into designing something without making a return! You've put the effort in, reward yourself at least a little!
Nah I've taken so much from the community over the years :) time to give back!
Honestly the per unit cost to land them is roughly $50 so plenty in it.
I dont want to make money out of this, the idea is to give to those who want but cannot do!
I've been building my rb24 for 8 years and been dicked around so much you shpuld not have to go through that.
I would suggest contacting Matt at Nistune and asking him if it would be possible to modify the code to accept your sensors. It might not be possible without some sort of interface box to make the waveforms look more like what the optical trigger puts out......but it might be doable. That could/would expand your market space a lot, and make a lot of Nistune users pretty happy too.
You could also look into doing a version with more teeth for those ECUs that will handle it.
Nope makes no difference the only thing to check is the signal voltage, you just have to make sure you use the correct signal wire off the cas if you want to use the factory loom and the other wire off the cas for your tdc cam trigger. That's it and done
It means there would be 36 teeth spread evenly around the trigger wheel.. But you take 1 out so the ECU has a reference point for start up..
Generally you need to attach the wheel to the balancer
You're too humble but that's up to you!!
If you had the time and inclination it would be brilliant to have brackets made that suit all of the more common balancers- Ross, ATI, etc. Most of the common balancers can be ordered with the trigger wheel as an option so they could be made to suit that. A lot easier to bolt on a trigger wheel than having to machine slots into a $700 balancer!
Anyway, good job on giving back to the SAU community, you're a top bloke for it!
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
    • The axels in my R33 seem tired, and have a bit of play in them. I cannot find any new of course, not interested in buying used, but I am looking to see if anyone can identify some cross compatible axles. In the states I have seen suggested for S chassis the J30 axles, however for the skyline (as best I can tell) the lengths are about an inch off (2.5cm) on both sides. R33 my measure L 22" R 24.5" GPT L 22.5" 24.25" J30 L 23.5" 25.5"  so shaft length is probably an inch wider. Not sure if someone has another still remanufactured option besides the J30. I figured worst case I can buy a pair tear them down and swap the center shaft. My other option was reaching out to GSP to see if they cannot piece together a set, since the axle stubs are still manufactured, I wouldn't think it be that hard to find a shaft or make a shaft work.
