also selling my kit as i didn't want to remove my ross balancer.
Cameron have you finished with this project or are going to try and design another kit?
has anyone thought about using factory cas for start position then something off the crank or flywheel>
Hi Robert,
At this stage I am done with the kit however if anyone is wanting custom changes etc. I am happy to work with them to produce one offs etc.
I do not at this time have room for different blocks and rotating assemblies to work on different designs.
  • 5 weeks later...
  • 4 weeks later...
Long time, no reply and I'm sure this will likely only help a few people but here is what I did to solve the tomei oil pump interference and smaller diameter fluidampr issue. Modified Murrayis's mount, rotated the mount, added a cylindrical spacer, tapped the actual sensor and I'll be cutting notches in my crank balancer. I'm going to go with (12x) .300" wide x .300" long and about .100" deep. The sensor is based on changes in magnetic field and should still pick them up even though the notches won't be totally through. Range on the sensor is .018-.080" inch. My .100" or so shouldn't affect it. I don't want to have a belt have the chance of getting freyed on notches.
LOL...exactly. Trust me I felt bad grinding and chopping on such a nicely machined part, but hey it's working and feels totally solid. And I left my spacer short so I can shim under it and move the sensor closer to the crank pulley if needed after I really torque it on the crank.
  • 7 months later...
Hey guys just got my car tuned at horsepower solutions and wanted to share my results from this trigger kit. Brief description is its a r32 with fully built 2630 running a forced performance super 94 with all supporting mods. I used a ross balancer and trigger wheel with murrayis kit. Worked a treat with only thing to do is space it apart with shims. Below are some pics
On 04/12/2015 at 9:36 PM, BlackBox said:
Hmm I really want to come up with a solution that doesn't require a gaping hole in the cover...
You can always just change to a custom made single window disc for the existing CAS instead of the the Murrayis cam trigger, that's what I'm doing.
I've already got the kit and got my balancer machined and re-balanced.. I am going to get a timing cover 3d printed to suit what I need
The last one I got was about $80, but that was for a CA18. Autronic sell them so do NZ efi. Just don't connect the REF to the ECU and use the Sync off the exhaust cam.
http://www.nzefi.com/product/24-tooth-cam-angle-sensor-disk-nissan-sr20det-rwd/
Maybe Matt could write different code for the CAS.  The Nissan one is providing 360 degree slots plus the 5 or 6 on the other circle.  The code might be easily enough altered to expect an arbitrary number of pulses on either of those.  Or maybe it would be a horrible exercise.  I'm not too au fait with decompiling the code out of (anything really) these ECUs.
  • 1 month later...
    • Come to Eastwood, you'll get plenty of that 馃ぃ
    • Oof, I will forevermore have those shredded gears in mind whenever someone talks about showing mechanical sympathy towards their car. Thanks for the photos, fascinating stuff!
    • Curious to see how the SpeedTek stuff holds up
    • The holdups last year were drivetrain related. I had the car out right after getting the bearing issue resolved. Third launch and the car didn't move after releasing the clutch. It had sheared all the engagement teeth off the 1st gear.    Thankfully no other damage was done. I set an aftermarket gear beside an OEM gear and found that the engagement teeth on the OEM gear were much larger and better supported. Looking through my bin of spare transmission gears I found that there are two types of tooth on the OEM first gears - the larger tooth and the smaller tooth. It looks like most aftermarket gearset manufacturers base their design on the smaller tooth. OEM large tooth left - Speedtek, OS Giken, etc or OEM small tooth right Decided to give that larger engagement tooth a try. Pressed the ring off an OEM gear and sent it to a transmission manufacturer here in the States. They did their "faceplating" operation with my synchro ring on the Speedtek gear.   I reassembled it, took it back to the track and promptly destroyed the gear itself.  I'll rebuild this and use it as a spare - thankfully just first gear and the countershaft are damaged beyond repair. Definitely disheartening but my welded on engagement tooth ring held up!  Moved to Speedtek's dog engagement design as the gears appear to be much stronger. So far they have taken much more abuse at the track. Also scored a Stillway lockout from the Netherands for super cheap. It's for some other RB transmission so it took a bit of fabrication to fit but honestly a very easy job. I also had to heavily modify the gates as they were very different.   Then for some reason at the last test and tune a silicon coupler below the throttle blew off and took out the radiator and fan. Thankfully it was in the burnout box and not down track. This car is really beating me up - I still haven't made a pass in it. Ran it through the gears many times on the street but it keeps biting me at the track.  Currently in the process of replacing the radiator and remaking the throttle pipe to remove the coupler and use a cast 90 and a vband. I WILL get this thing down the track...
    • Covers most of the above points really. There's a few exceptions but most just see driving as an irritating but necessary task they must complete if they want to get anywhere on time. Also see it as a good time to show their awesome multi-tasking abilities on their mobile and/or doing their makeup.
