Thanks for the interest guys...We always like having clubs come for tours as some really nice cars seem to fill our carpark. We will have a couple of photographers attending to shoot the meet so we should get some cool shots from it.
in terms of the talks itself. We are happy to be guided by you on this. One thing i have asked the guys to talk about is oil issues with Straight 6 motors, sometimes spending 2K on a Nismo pump isnt going to solve the issue like you thought it would. We are also going to do some work on E85 oils. This is a big issue right now as some of the biggest oil companies in the world dont have an E85 oil.
what else do you want to hear about? the talks go for about an hour, Then we have dinner and do a tour of the facility. We will also be handing out some sample products so let me know which oils you would prefer so it makes our job a bit easier.
See you all next week.
Thanks Dawzey!
The question I would like answered is:
what oil temps does Nulon like to see their oils run at. So minimum temp, maximum temp and the ideal temp to be running at. Also what effects does it have on the oil if you are running the temps to hot or cold?
Perfect question... i could answer it now, but where is the fun in that.
Another question i have is, How many of you are running E85?
I am and I know a fair few others who do as well. Very interested to talk about E85 oils
Hi Guys...
We would like to postpone this event for one week if possible and run it on Wednesday the 18th if it is OK with you guys? (One week delay).
This will allow us to add a few members that would be missing out on this event due to the timing, if this is a problem feel free to PM me and discuss and ill see what we can do. This will also help Nulon prepare and provide a better event for us all.
Can you please confirm that Wednesday the 18th is OK asap.
I am aware this is very short notice and hope it works out for all...
Cheers,
Mat
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
