40 minutes ago, Dose Pipe Sutututu said:
The dedication and sheer speed!
Mine has been on the hoist for 2 weeks, fuel system half arsed and yeah, Cbf lol
next track day is 20th august... need to start and finish the fuel system by then. probably should upgrade the rear sway bar to match the front too
  • 5 months later...
Purely to spite Ben C34.
Prior to the August 20th track day i did a basic fuel system upgrade.
Made it to the track day
first lap out and came in the check tyre pressures when i noticed there was oil absolutely everywhere.
I traced the leak to the catch can vent.
I emptied the catch can from the drain but only ~200ml came out so something was obviously a miss with the baffling. Without much time we decide to remove it and upgrade it to a dual HKS and Nismo system
This solved the oil issue and by the end of the day there was hardly any oil in the catch cans.
However, even with the baffled gated Hi-Octane sump I was still hitting engine protection due to low oil pressure.
The logs showed that oil pressure was now stable but capped off at around 50psi whereas before with the stock sump it would increase to around 90psi but drop to 15psi.
After some research it seemed like the Oil pickup may not be sealing to the block resulting in air being sucked in at the top rather than oil at the bottom as would the path of least resistance. When I had fitted the extended pickup to suit the new sump I had reused the old gasket style seal which the later model AWD RB’s have. But the extended pickup was of the older style which used an O-Ring seal.
So with a brand new genuine O-Ring seal acquired we got the car back on the hoist and went through the sump removal process which as you may recall from last time required the gearbox, clutch and flywheel to come off to get to the rear 4 10mm bolts.
New O-Ring seal fitted and back together went the car
this should fix the issue right? As the only thing that had changed from when it had good pressure but poor oil control was the baffled sump and extended pickup…
  • Like 2
Nope basically no change even had fresh 20W50 ULX110 oil which may I add required 3 bottles to do a change. The oil pressure at idle was low around 20psi and maxed out at 45-50 psi by 4000rpm.
We were thinking that potentially the Oil pressure relief on the oil pump was jammed. So again off came the sump, gearbox, clutch and flywheel. But to ensure if the pump relief was jammed I took off the pump as a complete unit rather than just removing the relief while leaving the pump in the car. Which as you may know required the accessory belts and timing belt to come off as well.
Oil pump off and relief shown. I removed the spring to check the relief valves range of motion and it was as smooth as butter with no scoring.
But as you can see the pump its self was rooted
There should not be any of those concentric grooves some of which were easily 2mm deep. So a brand new N1 oil pump was ordered.
while waiting for the pump to arrive I noticed that the Turbo oil drain rubber line had split
So this was replaced with a new hose.
New N1 pump arrived
This went in along with some new genuine cam seals to be safe.
and bam here we go
over 90 psi of oil pressure on idle.
so after four sump and gearbox removals we made it and time to chase that 1:19 at Mallala
  • Like 1
1 hour ago, iruvyouskyrine said:
Yes please, it's a neo now isn't it? Solid head should have less issues. Did you put a restrictor in the block before you put engine in?
Yeah Neo now never had any issue with the RB20 but was also only Nistune so not as much safety as the Link
Nah stock long motor have not opened it and let the magic out as yet
20 minutes ago, Dose Pipe Sutututu said:
HOLY SHIT, we have the same scoring marks!!!!!
Did you use Spool Import gears too?
yeah wild!
Nah just stock gears i considered going upgraded gears with the new pump but figured a brand new N1 should be fine
out for the first track day where i was able to more or less have an issue free outing.
and i manage to get my 1:19 finally!
I also generously provided some aero parts and a window banner for my Mates MPS (FYI i have a big ass sticker cutter now if anyone wants stuff)
all was going well until the very last lap when my AC pulley decided to escape. taking out my clutch can on the way
but hey drove there beat my PB and drove home
  • Like 5
  • Haha 1
  • 1 month later...
out with the old
in with the new
say what you will about GKtech fans but this was one of the original ones and didn't explode when a pulley went through it and was still good enough to get me home
also found out why my car was getting slower towards the end of the last track day
8 hours ago, iruvyouskyrine said:
I have found genuine nissan T3 gaskets to be excellent quality and only about $30 a go.
kinda like.. this one?
fresh OEM nissan T3 gasket
  • 6 months later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
