GTR jet & INXILE I'll do some digging tonight & advise the outcome, if you haven't already please email [email protected] with your details
Green s15, I'll be finalizing your membership tonight so will be posted tomorrow morning to you
Anyone else with membership issues please email me - [email protected]
I had a system issue which prevented me receiving new membership applications & hadn't received any forms since 5th January, but with this now sorted I've had them sent on to me & put in a few extra hours over the last week to try get everyone's membership packs out by tomorrow at latest :)
Also - If you haven't received your membership pack or renewal in post by 5pm Thursday & you're entered please email me, I'll send you a letter of confirmation via email that you will be able to show on Saturday/Sunday if the card doesn't arrive in time.
Cheers,
Anna
  • Like 2
I want a bottle opener :dry:
It is a renewal gift, you should get one when you renew next.
Hi all,
100% up to date with the renewals and new memberships now so if you haven't received yours by Friday and you are racing please let me know on email [email protected] so I can send you a pdf letter in meantime.
Cheers,
Anna
  • Like 2
No ones emailed me so far so fingers crossed that means Aus post did their thing & you all received your renewals and memberships & I don't have to spend my Friday night generating membership confirmation letters [emoji41]
I forgot about that sorry. Mine never turned up so I might need one of those letters.
Had my car booked in for braided brake lines, HICAS lock bar, bleed brakes and wheel alignment
Business owner sold the business lol
So ill just track it as is take it easy and she'll be right :thumbsup:
  • Like 2
Send an email to [email protected] if you don't have it when you check the mail & I'll reply with the letter.
  • Like 1
are you just going to watch Steph? Jake and I will be in Carlton around 7.30ish, but I'm not bring my skyline, just in the ute coz its on LPG.
yes im just watching :)
wanna meet us near Cranbourne at say 8ish?
we are leaving carlton area at about 7am....
Got knocked back for windscreen/suction cup mounted timer and camera yesterday (been running the same setup for about 5 years)
Any one else had/having the same trouble today?
Still annoyed at the ponytail CAMS scrutineer. Knocked me back for my Motocross helmet because apparently the chin part extends out too far. Told me to go speak to Clerk Of Course and see if he can over-rule it. Eventually he over-ruled it and then the scrutineer tells me, "They're not banned yet, but they're trying to ban them right now, it's yet to be updated".
WELL IF IT'S NOT f**kING BANNED THEN IT'S NOT f**kING BANNED!!!!!
In other news though I had a great day, good to finally get out there this year, definitely need to get myself some coilovers though!!
  • Like 3
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
