R33 350 Hp Build. Need Help
Lower parts are there. On passenger seat, bright yellow bit is the release mount. On drivers, bright yellow bit is the lower buckle for the other side. My bet is lowers are tucked out of the way as much as possible for visuals.
I'm guessing its a 4 point harness, 3 of the 4 belts are visible. I'm guessing the hidden belt is tucked down between the seat and door. -
Given the absence of lower parts, I'd suggest that they are just draped over the backrest for aesthetics in the photo.
Mixing things up - installed some leather recaros to match the leather seat covered rear seats. Interior looks pretty schmick now except for some slight wear on the steering wheel which I will monitor and address if it becomes worse or actually noticeable!
