Ok, pulling the dash out tomorrow to replace all the bulbs for LEDs now that they have arrived.
is there anything i nee to know, anything which is likely to break or clips in odd places?
for the main cluster:
im assuming its simply unscrew the surrounds and remove,
unscrew the dash and remove and unplug one main plug
then replace bulbs, i know their positive/negative and not to put it back together before testing... done that before
the ac i have done before on a gts so again im assuming the same.
tripple guage i dont know yet but cant be harder than a 34 gtt tripple?
ignore questions as search found it.
http://www.sau.com.au/forums/topic/115618-r32-headlight-switch-and-dash-globe-replacement/
...... Tonight's pointless post, brought to you by rebellion bay spiced rum.
Edited by GH05T
  • Like 1
Ok where is this ... vaccume hose? Supposed to go? Just pokin out randomly by my batter all of a sudden.
Dissappears under the plenum With the other hose which goes to the stock boost solanoid.
no free nipples...
heard that before
my guess is something has been removed or made redundant with the new intercooler hoses?
it dosnt have any vacuum or pressure and im starting to think it goes nowhere and hasnt since i have owner her.
either that or its a re circulation system for emissions and does stuff all generally?
Looks like a good candidate.
No chance of tracing it to the source ?
I'll take a pic of mine today. Got exactly the same thing. (Not connected)
I was curious and asked ESP about it and I was told it went to the sump :unsure:
Hence my comment above
Edit: I have a Nismo plenum and it appeared after it was put on
Edited by Sinista32
tried in the shed, my not tiny asian hands traced it simply to, dissapearing under the plenum, following the other vac lines from the boost solanoid but havnt traced it further. made no difference when running or revving and as said has no pressure or vac. and i just cant find anything else open ended to connect to within reach.
asked the Pavlou guys who recently did the heater hoses and they saw it too, they weren't sure what it connected to (not really looking as they were doing other things) but came to the same conclusion that it was doing no good or bad and left it alone which means it hasnt been connected for probably a year at least.
Edited by GH05T
hmmm, well im just gonna ziptie it out of the way for now. dont want it finding the radiator fan or anything fun like that.
will do some more searching later.
also
yay stock steering wheel
shit thing is... which is very odd, i still have the HICAS light coming on at exactly 10km into a trip. do i need to reset something or is it another fault somewhere else?
Does It run to a nipple next to the intercooler pipe? Line for the bovs.
Breather for the front sump goes to an upside down u shape bracket bolted to the underside of the inlet manifold. Usually a thin vac hose.
Not 100% sure if thats the hose you mean.
Edited by k_d
just a thought about the hicas light. does it keep blowing a fuse? check the fusebox inside the car, top row 7th along. its a 10a one. maybe try cleaning up the earth? theres the hicas module under the factory boost solenoid. the earth for it is close by.
i had mine come on randomly recently (light on and hard steering) and i blew a couple fuses trying to figure out whats wrong. cleaned up the earth and contact point, new fuse. all good now.
k_d
there is another pipe taking that up
will investigate the sump side when i get it in the air, cant see shit from under the bonnet.
on the hicas light, i will check the fuse, its annoying that it follows the exact 10km and fail symptom with the new steering wheel, is the stock boss not doing something maby?
my thoughts are going back to just pulling the bitch out and getting the martini locks.
in reading the hicas removal threads i do like the idea that you can plumb the unused system properly so that the hicas light still functions for low fluid or pump failing errors.
use the posted diagram to help you where find where it goes.
grab that rogue vacuum hose follow its path until you get to the end of it. it doesnt lead to the abyss you just havent figured it out yet.
how does the car behave? like a boost leak?unlimited boost?
has the factory boost solenoid been removed? do you have an aftermarket ebc? could be the line does not connect to anything?
stock boost controller is there and plumbed in, dosnt act like any boost leak and hits stock boost only.
i will get on it when i have a chance. probably when i get the plenum off to do the throttle linkages.
yeah i went, was an epic meet, i'm guessing 2-3000 cars.
32 ran well, had a chance to really rev it out and go for a decent drive which was nice.
On the run i pulled up at a set of lights next to a white 32gtr to which i strongly suggested he give me his grey dished panasports.... he declined :P
met him after and turns out he is Josh , owner of Forge Performance who i might go and see for a few things along the way which we discussed, nice bloke, not sure if i have seen him on here.
on that topic, we were discussing the car and some of its oddities/ rarities which include
no rear wiper
all the n1 bits (bonnet lip, sideskirts, rear spoiler (albeit missing) vents ect)
nismo 260 dash
we have been looking into its VIN which is still a bit perplexing, especially the last 3 digits which seem to be early 89 model only.
currently checking it out in the fast thread to see what it spits out, but it seems all the parts on the car are genuine and not just stuck on after which is nice to know.
will report back if it brings up anything of real interest.
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
