FIIIIIIIInally got the car tinted. why i didn't do that before summer i do not know.
anyway when they guys were tinting it they found that the top of the window was no longer sealing.
i knew the rubber was coming up, but the actual sealant between the window and glass has failed. water would be coming through it this winter OR, it would pop out... that would not be coos as its a genuine wiperless window and irreplaceable.
top ruber just falling away, would not reseat at all.
bottom edgings are shit aswell.
i plan to paint the car or at least roof at some point so i will be ordering a full set of genuine rubbers, seals and surrounds at that point, but for now i just need to make it functional.
window out, quick rust check, there are a couple of little spots but nothing that cant wait untill the proper paint.
this is the corner that failes, rust spot
We cleaned it all up and put some treatment on it and resealed it all up properly.
new seal
un sure what i want to do at the base, i have ran the seal under the old metal frames, i will be re-using these when i get genuine seals, but for now i have just left the tabs overlapping the new rubber, the only way it can be blended and sealed without genuine bits. it will do for now.
the little misfire reared it ugly head again, so i decided to rip open the afms,
the solder looked fine tbo, didn't seem cracked or loose.
f380e707-22c0-4961-bb2e-ddcca024ffda_zpsfc2cc972-1fd9-4ffd-a6c3-26301cb7ba5c_zps
but i re soldered them anyway, i honestly added the smallest amount of solder, and resealed them back up.
this is a shit job, cutting away sealant and trying to reseal them without it looking shit house.
but yeah, misfire completely gone, so happy when simple things work.
Edited by GH05T
  • Like 1
  • 1 month later...
haha, yeah their allot easier to tint without the wiper too :)
Flex fuel... maby, not for now.
remembering im still running a stock motor, stock turbos, stock injectors....for now.
pulled the spark plugs out for new ones, they are about 2+years old and looked healthy which is nice.
Josh at forge was nice enough to get me the haltech so we hooked it up. its got the tune from his stock gtr so it was drivable, feels sharper already, it will be booked in for a tune with Garage7 to get it up and boogieing. then I will look at new turbos-dumps-fuel pump-injectors - maby a new cam - yada yada... at that point I will look into flex.
it is no longer a daily so I can deal with the availability and added maintenance, so I should...
must resist using antilag with stock turbos :P
im very interested in the tune difference with the same boost from stock computer to the haltech. im not expecting more highend realistically but keen on the midrange. I will report back once its done to compare.
Edited by GH05T
Thanks man,
I'm eagerly awaiting a time i can get it into Garage7 for a proper tune, very keen to drive it finally knowing it has a proper tune. Up until now it has had its MINES ecu, while it had the 8000rmp rev limit on the box you just never know what its actually tuned for. like I said im not expecting more power specifically as I will essentially be running the same boost (depending of the AFRs it yields) of about 12-13 psi.
It made 258 rwkw last time which was quite respectable for stock everything except exhaust and pods.
im more hoping for the midrange and the sharpness and general driveability without being a rich pig like it was, and of course having the safety features the HALTECHs have so I can give it more without worrying so much.
just waiting for a booking now.....
Edited by GH05T
damn tune had to be moved to the 10th .... damn Anzac day deleted my day off which I didn't realise.... le sigh...
maby I should take this time and put a fuel pump injectors and a cam in it...................... you know...... for good measure...
  • Like 1
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
