Cheers, pretty stoked with how it turned out
Can't go wrong with vinyl when it comes to cost either; just under $400 was enough to get the whole car done.
Handled delaminated tyres, fuel, heat and more like a champ :D
  • 3 weeks later...
Got all of the little dramas from Matsuri fixed up, so tomorrow morning I'm off to a morning session at QR :D
Crossmember rack mounts moved 25mm forward
Thanks to the trusty engine crane and seatbelts
BAM, and the bind is gone!
Also fixed a heap of little things, so pretty keen to get it out there again:banana:
  • Like 1
  • 4 weeks later...
Headed out to QR last night, unfortunately after an hour of track time the oil pump gave up (suspected) :down:
My brother was driving at the time, but gopro footage shows about 3-4 seconds at about 2000rpm before he realised what the alarm was and turned the engine off.
Towed back to the pits and (after confirming there was no leaks from hoses and the sump was full) cranked it without ignition which revealed a really fast ticking noise and no build in oil pressure, so I'm pretty confident the pump gears shit themselves for some reason. :ermm:
So...
The plan is to remove the oil pump with the engine in the car and see what exactly I'm dealing with. Hopefully the crank collar is ok.
Any (relatively) cheap dry sump setups for sale? :laugh:
Tear down BEGIN!
Rounding evident on the collar
Pump is rooted
WP_20161218_16_16_17_Rich.jpgWP_20161218_16_16_25_Rich.jpgWP_20161218_16_16_37_Rich.jpg
I think I'll get some Perspex and hang this on my wall...
So I'll be removing the crank to fix up the collar (spline drive this time).
New bearings throughout and fixing anything else I might find along the way.
I get to give myself my own Christmas presents :laugh:
  • 4 weeks later...
Ripped the engine and box out over the Christmas holidays, everything is looking pretty good considering the failure
Had to get the grinder out to cut the cam cap baffle plate nuts off, dam things just spun. Raw Brokerage is the only place I could find online that sell the bolts, anyone know a better place?
Clutch is struggling with 4th gear, but it will do until a new turbo setup comes along
Big ends are looking healthy :happy:
A bit of emery paper and the cams will come up a treat
Crank will get a polish while it's getting the spline collar installed
All the bearings, plastigauge, lube, Loctite, gaskets and fluids are either in the post or sitting in the shed... so as soon as everything arrives I can put her back together again. Hopefully around the start of Feb
While I was bored (after ripping everything apart), I started mounting up a front splitter. Curious to see how it will go :laugh:
Tomei do a stud and nut kit (pretty sure it's just rebranded ARP) that replaces all the bolts with studs. perfect run or RHD Japan
Part numbers for washer that goes between the cam cap and bolt 01311-00711, bolt 13058-59S00, the washer on top of the baffle plate 08915-4361A, spring washer 08915-1361A and the nut 08911-20610. The place to get them would be Amayama or RHD Japan.
Could you do me a favor and measure the height of your flywheel?
  • Like 1
Dropped off the crank and spline drive to the machinist shop yesterday
Unfortunately the crack testing revealed some pretty bad cracking around the No.6 big end and main.
Luckily a mate has a good condition crank (will get it crack tested to make sure), so fingers crossed everything goes smoothly with this one
Found a pic of one of the last laps before the pump gave out :laugh:15977738_1911247445774485_1615082053375432178_n.jpg
Edited by Yonz
2 hours ago, AngryRB said:
What oil pump was it? Stock RB30 or aftermarket ?
Aftermarket crank collar with a N1 pump and billet gears
2 hours ago, GH05T said:
dont use a splitter made of wood, seen it done, seen them catch fire.
I was planning on laying heat reflective tape over it for the first couple track days, to see how it goes before committing to something more substantial.
I'll be keeping a close eye on it, but if that isn't good enough I might just bite the bullet straight up.
18 minutes ago, ruinned said:
How many meters of wrap did it take to do the car ??
5 rolls that were 1.5m x 3m each
that's alright 15ms of any wrap is pretty cheap now days :D
how did u do the roof, since there is no weather strip there ??
yours looks awesome as well
Yeah, well worth doing if you have the patience for it :happy:
I did the inside of the ridges in the below pic as one sheet, then I layed the whole side of the car from the A pillar back with one sheet; which slightly overlapped the wrap on the centre of the roof.
Thanks, a YouTube tutorial was my only previous experience :laugh:
Faintly visible cracking in the pic. It looked pretty impressive with the dye penetrant glowing under the UV light
Good news for the other crank though, just waiting on the collar to be fitted :D
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
