I had always wanted a standard looking clean interior. I believe now i am well on my way to achieving that.
Randomly on FB a woodgrain stagea wheel popped on my newsfeed so i snapped it up straight away. I still need a gearboot and an mp3 player that looks standard. I will change the led's to match the climate control.
I made a glovebox cluster out of redgum to hold my gauges and safc neo.
First was to make a template out of cardboard.
Then i clean dressed the redgum to let it air for a month, this was done to limit it's moisture content and it will have less chance of expanding and contracting with the different seasons.
I then deep ripped it on a bandsaw and cut out the template, i let it dry for another month.
I used an edge router with a 45deg ball bearing tip to get the perfect angle.
I used a 48mm holesaw to get the gauge holes and then used a bobbin sander to achieve a tight fit for the gauges. The safc neo hole was achieved by a 10mm drill bit, jogsaw and a hand file.
I then used a stain and a satin oil finish, each time i stained and oiled i sanded in between, there are 6 coats
I am not too happy with the finished product as i rushed some parts and steps. This is it all in, excuse the mess.
I attended the ACT's first all japanese car show hosted by REACT.
I met cpark, sin and a few others there and was a great start to my birthday!
  • Like 1
Really digging the wood highlights, Ive got a few woodgrain interior pieces around somewhere...but not enough for a full set. I have a RWD woodgrain piece for the centre console, but it doesn't fit a 4WD model. I assume your centre console is also not off a 4WD S1 stagea?
Thanks tofu, redline and zoom.
The glovebox is a funny thing. Nissan didn't think i would notice that the latch hump is offset 5mm to the right and the sides taper inwards at the top.
After seeing HKS and freeway Dolphins glovebox consoles I knew I had to make one.
I'm very lucky my boss is a great guy and let's me make my own stuff on the weekends.
All my woodgrain pieces are from the s2 Stagea that's why the centre console needs a boot to cover the gap.
You should check out ebay and yahoo auctions, plenty of random wood bits out there for decent prices. I got lucky with my stuff, but I was always searching for the right pieces for the right price.
  • 3 months later...
New regu 06&r muffler, this took a bit of work to get it to sit where it is. I now know why Stagea muffler tips are always 200mm long.
Stitched a shift boot.
And went nuts on Stagea magazines.
Purchased an innovate lc2 wideband and will probably have to make another glovebox console for a change of plans.
Benny I haven't forgotten about the cargo blind ;) I just get sidetracked very easily.
  • 4 weeks later...
  • 1 month later...
  • 2 months later...
Been prepping for track days recently so first up was brakes.
Setup consists of; R33 gtst calipers - DBA 4000 T3 rotors F+R - Remsa/Roadhouse pads F+R - TRW GP600 fluid - Nismo braided lines front - APP braided lines rear
Huge thanks to Luke, Joe, raj, and Kyle for the brakes.
Got a new helmet. Very cheap, comfy and sa2010 complied.
Put in some whiteline rear upper arms thanks to grant and caster arms with whiteline bushes thanks to Ben.
how does the new kakimoto muffler sound? does it have the silencer in it?
It's ok once warm but terrible when cold. No silencer, using a trust mid muffler too.
Honestly I can't tell you exactly how it sounds as I've never heard it outside the cabin.
  • 10 months later...
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
