2. run a tank of 98 every now and then to clean out the fuel system and avoid gummy buildup in your fuel system
How often do you guys fill up a tank of 98 to clean it?
United have very rapidly raised their prices, I have been considering getting my car retuned back onto 98 so I can get some kms per tank again since I'm not seeing prices as low as they used to be at the pump, it's a joke how much they've raised it.
its not really united, its now ethanole is trading on the same market as oil so market price is set along side oil price so varys as much when it shouldnt as its an entirly different economy
http://www.agmrc.org/renewable_energy/ethanol/ethanol-gasoline-crude-oil-and-corn-prices-are-the-relationships-changing/
This sort of explains it, basically instead of being set separately to oil prices all together as it should be the bulk ethanol prices actually is dependent on crude oil prices.
Making it not as cheap as it should be. Can't find the original article I read saying it's now being set the same way the parity pricing agreement with oil works.
From my understanding of ethanol, I wouldn't bother with a tank of 98 to "stop it gumming" as Ethanol is a solvent, which means it will actually clean out the gummy build up, as well as help clear up carbon build ups etc.
No point whining about it, I heard every excuse for not running e85 in Sydney over the years, it's too far away to fill up, Caltex e85 isn't consistent, not enough servo's to run e85 daily...
If more e85 was being sold they would have put more pumps in, end of story. I used to drive 22k's each way to fill up, in the snow with bare feet.
  • Like 1
They need to open a united servo with e85 in Sutherland shire
Doubt they will until Caltex pull their Eflex from kirrawee. So easy for everyone to fill up there on their way to the nasho
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
    • Hello everyone, I am happy to join you.
    • Whereabouts are you, that looks exactly like Akira's old car....
