Hey guys, i'm a bit torn.
I'm looking for a RB26DETT car for my next ride and i'm stuck between R33 GTR and a Stagea 260RS.
This is going to be my DAILY and it will have to run a 11 second quarter mile
They use the same engine, most of the same components, both AWD and same power etc.
I was going to go for the R33 for the weight but I found out it's actually not that much of a difference(about 200kg I think). I like that the stagea is very unique and uncommon (sleeper) but the GTR has a sportier look and feel.
Now i understand this is completely personal choice but I wanna see what you guys think!
All opinions and thoughts would be appreciated :)
Here's the link for the poll. fire away!
http://strawpoll.me/3564871
https://www.sau.com.au/forums/topic/453515-r33-gtr-vs-stagea-260rs-autech/
Why dont you create a poll here? :huh:
oh i didn't know i could do that!
I think you should decide what you want and get it. I don't see the point of a poll. Are we deciding what you buy?
Just trying to get some opinions. I'm having a hard time deciding :) what would you get?
Either of them modified to run an 11 is going to be a major pain in the ass to drive daily IMO.
Better off getting one for a weekend toy, and a shitter for the daily grind.
I thought they could run 11s with around 300awkw? Could be wrong.
My R33 GTR ran a 12.3 and had a little bit more in it. It could have squeezed another tenth or two out of it. It was ok to drive around but the clutch made it horrible in traffic.
If you can avoid traffic or get a nicer clutch then you'll be fine with it as a daily.
How much was it worked? Built engine? also how much at wheel power was it pushing at the time?
It has to me be my daily as i can only accommodate 1 car but i'm happy to fall into the 12s.
Not much at all done. Stock turbos, stock engine, just management, boost and some other little bits n pieces. From memory it made 260kw at the wheels.
that's good to know! RB's impress me every day.. what a machine.
$15k stag wagon daily
$15k 33 gtr to mod for the strip.
whats your budget, the compromise trying to do both can be expensive and well a compromise in both directions.
spend $30k (probably less)to buy 2 decent cars
spend another 10-20k (could be heaps less could be heaps more) on the gtr and have a track weapon and dont compromise so much.
Yeah, daily drives would be awesome without traffic! Lol! We all know there are some crappy commutes in Sydney. Can I get a Amen!? M1/2/4/5 all horrible.
Problem as I see it, you have an older car with some suspect reliability depending on whose flung spanners on it in the past. You have something you really can't leave at a train station cause you'll never know if it will be there when you get back, kids will open doors into it and scrape is bumpers in the shopping centres and make you cry.
Having said that, look at a Series 2 C34 manual. The VCT is a positive compared to the 26, you have a much simpler turbo system, chuck a hypergear high flow on it and it'll make good power with the usual upgrades, but won't stand out and be a massive sleeper. Chop plenty of GTRs in that and it'd be a laugh.
  • Like 1
I'd get a Stagea so I can lug my dog around in it (would actually do this if I could sell my R32 GT-R). But since I already have a daily, GT-R all the way!
yeah... don't have money for that :)
Don't get me started on the M2.. OH MY GAAWWWD it sucks.
You've given me a bit to think about.. maybe the rb25det could be a good route for a daily... I'm happy as long as i'm chopping rexys
Yup.. I'm leaning towards the stagea just because it's different and a mad sleeper.
I'd suggest the GTR as a strip/weekender and getting a cheap daily
By modifying the stag to do an 11, you are removing practicality i'd seem to think.. in saying that, my friend recently bought a stag, just the rb25det version and it's very fun to drive and be a passenger, and nobody seems to know what they are when you boost past them lol
The autech stageas still command a higher price than regular C34s. Im not sure the extra money is (only) buying you hardware, you pay for the rare factor.
If you are going to mod a C34 with plenty of cash to spend, you might as well get a cheap chassis then do an RB30 conversion. Stageas need the torque down low.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
