2001 series 2 R34 GTT 5sp Manual $13000 obo
GTR pearl white colour
ONLY $10000 without Rego/RWC on stock rims and I swap stereo to standard
250rwkw and very track capable
Located Holland Park
Rego till November
Timing belt, ancillary belts, bearings and water pump done 20000kms ago
Engine
Bosch 023 fuel pump (installed properly with constant 12v from battery)
Nistune
Z32 AFM
Splitfire coilpacks
Hypergear G2.5 turbo 10000kms old
550cc Bosch Injectors 10000kms old
3inch turbo back exhaust
ARC return flow intercooler
Oil cooler with thermostat
GTR BOV
Manual Boost Controller
52mm Allow Radiator
Suspension/drivetrain
BC Br coilovers 20000 kms old
Cusco 1.5 way LSD with solid mounts 10000kms old
Whiteline H/D swaybars front and rear
Subframe lock collars
Nismo gearbox mount
Extra lock steering spacers
Polyurethane steering rack bushes
Adjustable Front Camber Arms 15000kms old
Adjustable Castor rods 15000kms old
Adjustable rear camber arms 15000kms old
Adjustable rear traction arms 15000kms old
Adjustable rear toe arms 15000kms old
Hicas Lock bar
Stereo/alarm
Autowatch alarm + immobilizer
Pioneer head deck
Rainbow splits front
Rainbow coaxial rears
4 Channel alpine amp
Clear front bar indicators
Spare series 2 front bumper
Rims
4 Stock series 2 R34 rims
4 Gmax 18x9.5 +35 1 pair shagged tyres 1 pair 90% tread (have pair of camber worn ATR's with plenty of meat for drifting but not road legal)
4 genuine work rims 2x 17x9.5+27 Front 2x 17x10 +32 rear
Bad Parts
Marks on rear left of bumper and right side from tyre walls at archy.
Dent in bonnet.
Sits 4wd spec as exhaust needs to be tucked to have lower to be legal
Have a few options for sale
Everything above+RWC and rego for $13k
I can swap stereo for stock system and take off $400
Willing to do deals/cheaper with me keeping rims/bits
Video of car at track:
http://instagram.com/p/gWqAl8vN6d/?modal=true
http://vimeo.com/77018212
http://vimeo.com/76944207
post-67189-0-76386200-1423354203_thumb.jpgpost-67189-0-63142300-1423354268_thumb.jpgpost-67189-0-61598900-1423354325_thumb.jpgpost-67189-0-15148500-1423354356_thumb.jpgpost-67189-0-86458200-1423354401_thumb.jpgpost-67189-0-45811500-1423354422_thumb.pngpost-67189-0-54224800-1423354460_thumb.jpg
Edited by Marcus89
https://www.sau.com.au/forums/topic/453615-daily-driven-track-proven-r34-gtt/
  • 3 weeks later...
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
