What is different about it other than the RON?? If it is just a higher octane fuel, it is a complete waste of time. Nissan specify 96RON fuel, using anything higher is of no benefit in a stock engine/tune. If it costs more, it is flushing money down the drain.
Burns hotter. So it's cleaner. If your car is tuned for it you'll get more power.
Better economy.
If your worried best to ask Nissan. Say to them you have a 350Z. ;-)
have you seen the price of that fuel? Its certainly not economical.
Tuning for it is completely stupid.
Edited by Ben C34
Ya i took it into my mechanic, he isnt really sure what it could be. His thoughts were either a missfiring spark plug or pinging. He said he wouldn't know until he started changing parts
Go somewhere else. A misfiring cylinder doesn't sound like pinging. ...
VQ's rarely ping, the knock sensor is pretty good at picking up knock and dropping timing out. Are you sure it isn't just a bad batch of fuel in the tank?
If it is indeed pinging, I would be looking at fuel supply. Have you changed the fuel filter at all?
Does the noise sound like nails dropping on a tin roof?
This.
This.
The noise been happening for a while. It only happens in certain revs, at the star it would happen between 1.7 - 2.2 but now also does it between 2.8-3.2. It sounds like a metal on metal sound, i guess it kinda sounds like nails on a tin roof. I always use bp ultimate but once last year used 95 for some reason. I dont think the fuel filter has been changed...
Check your heat shields aren't coming loose. I've had a light metal rattling sound since shortly after I got my Stagea, always around 2000-2500rpm on light/medium throttle. I came to the conclusion a long time ago it was most likely a heat shield rattling due to engine harmonics. I'm just super-lazy and haven't bothered crawling under it and prodding things around.
Another possibility: I don't know if the V35s are constructed the same as the Stageas but mine has a twin-walled exhaust, with the outer layer having corroded through, meaning lots of thin, small strips of metal to tap against the inner wall. Any day now I'm hoping the inner wall will rust through and I'll be forced to fit something better.
Performance hasn't dropped off at all, it burns almost no oil between changes (5,000km) and the noise is always under the same conditions.
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
