Hi,
I'm upgrading my trans cooler and I'm wondering if r34's have a thermostat on them already so I can just take the hoses off the stock one and put them on the new one. If it doesn't have one what would you guys recommend for one ? Preferably something not too pricey..
Also is the plumbing for the trans cooler just 1 line from the box to the cooler then 1 line back or is it connected to anything else ?
Any help would be greatly appreciated ! :)
https://www.sau.com.au/forums/topic/455375-r34-gtt-auto-trans-thermostat-help/
No thermostat stock, generally you need to leave the fluid going through the radiator on a road car.
I run a $30 inline transmission thermostat off ebay, the blue ones. You will likely see them if you look through. They are 10mm fittings so you may need to muck around with the 8mm lines to get it to fit.
A trans cooler can never be too large, and it needs to be after the radiator outlet and thermostat. You will need to work out which line is pumping out and which is the return without making a massive mess preferably. :P
R34s have a small external trans cooler. I would expect that there's no thermostat involved because it's not very large. You could probably double or triple its size on a car being worked hard without too much problem, unless you end up driving it around gently in cold weather.
The question of whether you actually CAN run a thermostat in that line is another problem. I don't know if the cooler line runs the total flow of some circuit or if it's just a bypass. If it's not a bypass in it's own right, then a thermostat in that line would need to have a bypass in it to return flow when closed.
Hi,
Something else - normally the radiator . This helps to bring the auto up to temp quickly from a cold start. I would guess temps are normally high where you live so a thermostat may not be necessary. If you are keen you could install a temp gauge for a while and see what you get.
No need for an inline thermostat with autos unless you live where it is really cold
If you do fit one make sure it has a bypass until it warms up otherwise you'll starve the rear planetry of oil and damage it
Fitted my stand alone davies craig 679 and driven it with no problems in 6-10deg weather every morning. It is placed behind the grill and takes roughly 10min for the trans to go into lockup if driving like a normal person on 60-80k roads. When the weather starts to get colder if I notice any adverse affecs I will add a plate that can sit over it and shield it from air. It got rid of all flairing inbetween gears and shifts better than before. (Could just be masking another problem)
Thanks for all the help and suggestions guys. But as this is a daily and gets used in mornings when it's fairly cold I'd like to be able to get it to temperature quicker and I'm not a big fan of cooler covers. Also since I'm doing a shift kit, trans temp gauge and trans cooler I'd like to do it properly and add the thermostat while everything's pulled off.
I'm slightly confused with the plumbing of the stock cooler but. Is it not just a straight line from the tranny to the cooler then a line straight back to the tranny ? Or does it connect to the Intercooler as well somewhere along the line ?
Ah that's what I wasn't sure about. Cheers for that guys. Also cheapest I can find an external thermal bypass is like $50+. Is there any thermostat from Supercheap or something I could use ? If so what one would you recommend and does anyone know what's the minimum temperature for safe performance and for the thermostat to open up ?
Cheers
Cheers for that
Also reading the description the Inputs and outputs seem a little small in diamiter. Won't that restrict flow?
And while I'm here I'm looking to install an oil temp gauge and I need a housing for the temperature sensor. Would you happen to know where to get one ?
The hosing for the Davies Craig kit I bought looks pretty wide so I just wasn't sure. And good idea with the bung on the sump but I'd like to do that as a last resort
3/8 is loose on the 679. They are thick lines, that's all.
I believe Scotty was talking about a temp gauge in the last auto thread, using a sensor adaptor for the 3/8 lines.
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
