The bonnet is shut. :P
Haha
But it does stand out and makes it look even bigger.
I am tempted to get it done locally, going to see another mob tomorrow and see what they have to say, should at least be interesting :)
Go twin 3"
Exhaust sits higher (avoids defects), flows better however its more expensive and heavier
It's a single, not low mount twins. Lol
I'm sure a 3.5 or 4 inch will be more than enough.
Hi Pete can't believe the things I've read and seen mate UNBELIEVABLE! I really feel sorry for you :(
Have you had an explanation on why they made such a tiny exhaust?
IF you are coming to Sydney again id gladly knock you up something REAL nice. I can shoot you some pics of my work if you're interested ;)
  • Like 1
I'll knock you up real nice!
Serious that's a good offer though.
I saw the work you did on Daves car.. Verrryyyyy nice
  • Like 2
Thats a great offer, love to see some pics of your work, How long does it take to do something like that. I would have to get the down pipe and Cat sorted before I give it to the builder or get them to do it before they can really fix the farked tune , thanks for the offer, I do not know what to do at the moment :/
My problem is I am a single Dad and have no other family here where I live and the kids have to go to school etc. When I drive down and if it is going to take longer than a day or 2 at the most, I have to fly back. So each of these trips cost me about $800 return.
This is why I try and get everything done at the same place at the same time, seems it is not working out real good,haha
I feel the build is so close to being finished but with a lot of nagging problems that need fixing and the builder has to fix the ones that I feel are his responsibility and I need to give them a chance to sort this shit out.
Mick_O , no one explains anything because I think it could be like admitting that they caused a problem, no one in business likes to give themselves up and take responsibility for a fault and they try to dodge the bullet :)
If it's still losing water and it's not obvious where from, it'll probably be staying with them more than one day.
Sure will, just hope that is an easy one to find or it could get ugly.
I will drop it off and if they think they can do it in 2 or 3 days I might be able to have the girls looked after and stay in Sydney until it is done , but I do not like using people up with this type of thing as there can be more important reasons for asking for a favour.
  • Like 1
Disable the car and chuck it on the back of a transport truck and deliver it to them. Job done and no favours asked.
Haha, you jest !
Do it that way and it would be tucked down the back somewhere until " they had time to look at it "
I will wait until they have the time and then give it to them :)
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
