Out of interest Pete, what/who made you go for the 3.2L stroker in the first place? Given the expense it seems like a curious mod path (to me) given what you wanted from the motor and given you had no prior experince with RB motors!
I know what you mean about no experience, haha
I bought the car on a spur of the moment thing, just liked the look and the history of the Skyline.
Did some mods on the car and it started to drive better but still too laggy, I decided to get it going the way I would enjoy it as a DD, so Nitto 3.2 Stroker was the best way I could find to help get the response I wanted. Got lots of help on SAU, OH and lots of smart arses, some good stirs but all good fun :cool:
Did the drivetrain with the build , they are great mods and it is all coming together. This is really the dumbest shit I have ever done with a car, but loving it!
When I am finished I will be happy I did it. even now it is great fun to drive and sticks to the road like shit to a blanket, even if it wont rev past 6500 rpm without farting.
I will do the next mods and see what happens :)
The excuse was that "it was setup for a 2.6L".
With those turbos and the restrictive exhaust setup..... no shit it was laggy. No wonder the thing can't make power and is far from sorted at the moment. But surely the builder would have told him that when they were considering the build. Given the current circumstances, running rich is a given.
Isn't it the same problem for every RB26/3X conversion in a 32 onward Skyline unless engineered?
not in nsw, can increase capacity by 20% as long as the engine is from the same family as the original
The PT6262 Turbo and the 3.5" exhaust system from the dump was already in the car before the build was done but they left the 3" dump and 3" cat on when they did the build, they modified the top section of the dump pipe to fit the new Turbo location and left the 3" cat on. When I asked about it I was told it was a better setup for response and if I went bigger it would give me more top end and loose bottom response ,.
I agree, I can never understand why people spend money wanting to make power and get caught up in 'you can get away with a 3" exhaust'... the best exhaust on a turbo car is none at all... no restriction.
I can't help but think either that this build should have been a 2.6 with GT-SS considering the power it has (not) made, not offence to Peter but the money spent here is bizarre for the given result.
  • Like 1
I pulled that up this morning, read a bit but will have to look at it later on.
Ben, no it was never mentioned and I had asked a couple of times without a response.
Michael , no offense taken, I left it up to the builder to do what he thought was best for the build. I would have done whatever he suggested needed to be done, as long as it was not noisy or peaky, I did not try to save money on the exhaust. There were modifications on the dump with the build, it was just not a good choice.
I chose to leave the PT6262 on and had the flex Fuel Sensor and ID1300 injectors added . I figured that if I need to change anything else I would wait and see how the bolt-ons I had on it would work together.
It is not finished, so wait until the fat lady sings. I think a lot of blokes have spent more on their cars over the years trying to get what they want, I just spent it all at once :)
When you talk about power it has (not) made, where would you put this power in a DD and how would you make it better, always open for constructive criticism ?
I think the point being made here is that for anyone else considering a new setup and reading this thread, is maybe they should consider optimizing what they have first and see if it satisfies.
To say to make this setup better you will fix the exhaust restriction and put it on e85 is great but if you did these things on you old setup, I am sure it would have driven closer to your liking, ie more response and power, actually i think it would have changed it significantly.
And its not a matter of people spending more money its a matter of spending it smart.
No disrespect here just an honest view on what I know from your history on the forum. Hope it all is smooth sailing from now on mate.
Lucky we are in NSW thn :)
I agree this build has fallen short on what it should be making in both power and response, fixing the exhaust will help that a lot
Spending some time dialing the cam will help to, i have seen results from these cams on smaller engine and the inital take iff is way better then this build
And my own personal opinon from my experiance with CRD is get someone else to tune it if your happy with their next try
  • Like 1
I am sure just about anyone could have done a better job building this car than I have, but it is my car and I do not worry about the money being wasted, I am happy the way it is coming together, no problem :)
The car drives "much better" than it did as a 2.6 and once the changes are made it will be a very tough all rounder, quick and a beautiful R34GTR, what else could a bloke want :)
I have no doubt that someone, probably everyone could have done better than I have up to this stage. Even with the shit going on, I have enjoyed doing it, I can afford it, would have been easier I knew what I was doing , but thats how it is.
The old set up was crap compared to how it drives now, even with the existing problems I am happier :)
This car already drives great, plenty of torque from idle right through the revs, it is strong and linear, well until it falls over @ 6500rpm :) but that will be fixed very soon.
I am not doing the E85 to get response, I will probably hardly ever use it, just wanted to have it there should I decide to use it.
Doing the dump pipe and Cat only because it is not doing the job and getting back pressure trying to squeeze it through 3".
I might be having myself on but I reckon my car will be a very tough all rounder and be pretty quick :)
Oh mate don't be mistaken, this isn't your fault
CRD have done every thing to this car and the 3.5" dump and good cat should have been done or at very very least talked to you about when the 6262 was fitted
Your setup is what i would consider the perfect setup for a R34 GTR, even better if RB26 block based for fitment, and what the R34 GTR should have had from factory or at very least a 3.0 with twin -5s
  • Like 2
No worries Mick, the car will be all it can be for the way I want it to drive and thats all that matters. I will PM you
A beautiful R34GTR, tough, fast and great handling, what else could I wish for . When it is finished will be the best time to judge it, until then :)
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
