Leave the poor guy alone. I would also be very edgy after everything he has gone through with this car.
True. Sorry mate.
Sometimes a bit of friendly banter gets taken the wrong way if your not in the right frame of mind.
But the main thing is that Pete beat the Tiida .... That's the main thing even at 10000 rpm. Would have sounded awesome.
  • Like 1
Bit angry today Pete
No mate, its all good fun :)
I have never said I was any type of gun driver, I just like cars :wub: had a 911 and a TT300zx I used to push a bit, but I was a kid, 50 year old.
Everyone has their preferences , mine is a car that dives like a street car, one that has a bit of grunt from down low.
Do not need 3000 idle Ben, is that how you blokes do it. Me at 2500rpm and want to get it going in any gear drop down 1 gear and away you go, LOL
But serious it is great on the twisty stuff, so much fun. Not sure you could do the same on tight one lane roads with a T88 or something else that gives you 700 or 800 peaky HP, but I can only guess as I do not drive fast GTRs , just my heap :)
My car is the best fun you can have sitting down, well , a lap dance maybe ?
True. Sorry mate.
Keep the banter coming mate, that is what makes the Forum fun, farken love it :banana:
Have you got your car back yet Pete?
Not yet James, had an email this morning saying it looks like the leak has been fix but they will do some more tests over the next couple of days to be sure .
Not sure if they will be doing a new Dyno graph , soon see I guess ?
Things are looking up :)
  • Like 1
At 70, I hope to be a much much more bitter and twisted old man than you. Pretty sure I am now at half of 70.
Oh don't worry mate , I was very bitter and twisted at 70 but now I am 73 I have matured , guess it comes with age , LOL
Just thinking to myself.... I feel more anxiety over and your car in than my own. Ha ha. Ha. Might have to drive up from Melbourne so you can take me for a spin when you get it back.
HAHA, that's why I have chilled, I left the anX to you. I lie , I had / have enough anxiety for the both of us. It's been a long 9 months :)
And it's not over :/
Edited by Nismo 3.2ish
They are probably just putting the head back on now pete, takes more than a few days to strip a motor again, lol... :ph34r: apprentice stuffed up again..
Thanks Mark, now my head is exploding thinking about anther 5 months getting the motor re built :bomb_ie:
No problems, I will be picking it up VERY soon and looking forward to a little spirited driving to see how it is running :)
Got a date for pickup? Good RB30 blocks are getting harder to find.
They are going to do a few more tests and I should know by Friday :)
Just hope I got one of the good ones, they did all sorts of tests on my RB30 block, like below
ENGINE MACHINE WORK INCLUDING HOT TANK BLOCK, ACID
WASH , BORE AND HONE , BALANCE ENGINE COMPONENTS.
DECK BLOCK, MACHINE BLOCK FOR O/S HEAD STUDS,
MACHINE WORK FOR AWD ADAPTOR AND ENGINE BRACE KIT.
MACHINE SUMP RAIL TO TRUE UP ENGINE BLOCK.,RELIEVE ENGINE BLOCK FOR 3.2LTR STROKER ENGINE.
1.000 SONIC TEST AND XRAY ENGINE BLOCK TO TEST FOR SUITABLITY
Sounds like they did their best
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
