haha, thanks
Hope I do not get too bored too soon, well the builder should get bored before me, he had it longer :)
When you get bored just put a bigger turbo on it. Response gets boring quickly.
I will look out for your next thread, titled ' I love my car BUT its missing something' ha ha
I think you should relocate that number plate just quietly.
And I hope you don't have another misfire. That would be beyond a joke
I like it there, no obstruction for the air and you do not have to bend it at each end to go into the original position , a lot of Plates look like they have been nailed on, see great looking Rs and shitty plate positions and conditions ?
Not worried if it is missing again, I am not going back to Sydney and I am sure I will find someone closer and go from there.
Shit mate if everything worked the thread would closed and my life as I know it is over :(
Just watch this spot mate, I might have to steal your name for the thread :)
I never got sick of a car with response and have been loving response for over 55 years, but it took about 2 klm to hate lag and want to sell the car.
Big turbos are exciting and I am sure my car would be great with a big modern turbo, that is, if I could ever use it :/
Each to his own mate, just got to love cars and driving them :cheers:
Old wives tale........ You can always use it..... He he ....... Always. :D
haha, but getting it up to 7k and dropping it at the lights or out of Woolies car park is not a good look, fun no doubt but is frowned upon by the boys in blue :)
Where is the RPM on that Graph?
Is it 300kw just under 4000rpm?
Max torque is extremely early - beauty of 3.2L ay.
I want to compare my graph - same power just .6 of a L down.
Edited by Stixbnr32
Mmmmmm, some falsely say it is the case. Never had to do it myself. I think people talk a lot of shit really, or just don't know how to drive.
The next tune I have done will have RPM and you will bet a comparison , I find these Dynos without the rpm to be a pain. I will try and have the few things I need done ASAP and it should be interesting to see if they can do more with the tune and cam dialing ?
Is there anyone reading this that can put the revs to the KPH.
Paul was saying that I have lost 5.2KW but at 18.5psi not 22psi on the last tune , as you can see the psi drops off from 24psi @ 351kw and makes full power @ 18.5psi of 381.7KW, so I guess it really did not loose anything with the new dump ??
Stuffed if I know how it works :/
Looks like your making the same power with less boost. That's a result of a better dump (good thing)!
Also what Hadouken is saying may also be true, the spark could be blowing out which is why there is now less boost.
If this is the case there's an easy solution to this problem.. It's just more $$$
You might be right about the driver , me :)
I had a T78 so not a new age turbo but it was hideous as a DD , but I guess we all have our own idea of lag for a STREET CAR, " not track or hill climb." as I know shit all about this type of driving, but I know once the revs are up they are great.
Turbo is too small. Turbine housing too small which restricts flow and chokes the engine. In this scenario you have no choice but to cut boost.
It will be interesting to see what an e85 tune does because if it makes no significant difference then the turbo selection is the problem.
  • Like 1
New coil pack ?
Interesting that the boost tapers of so much, would be alot better if it could hold.
What wastegate and what boost controller peter?
He said he cut the boost , but I do not understand that as the last tune was 22psi and this was at 24psi to kick off and dropped off to 18.5 psi?
I put the PT6262 CEA Turbo on it as a 2.6l, left it there to see how it goes.
Personally I do not care what E85 does , I cannot buy it here, just like having the option and would love to feel the difference from pump .
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
