Things don't seem to be necessarily optimal, but I'm not expecting to see miraculous improvements in power - perhaps some improvement in power delivery if it turns out the intake cam proves to be excessively retarded in practice.
I also do not expect any real over all power improvements. What I have is plenty.
What I would like to know is, if you have your intake side retarded by 3 or 4 degrees and you advance it 3 or 4 degrees , there is 6 or 8 degrees difference, what would this do for the low end power gain at lower rpms.
Never heard of an external wastegate opening due to exhaust pressure tbh, I'd consider it a design issue if it did - by function definition they are meant to block any flow until the reference pressures met targets - especially if it had both ports utilised.
If he is bleeding off a 12-14lb spring and has a higher than expected exhaust manifold pressure at wot due to a restrictive rear then the gate will crack open, no question. This always happens in this scenario, not the first time and it won't be the last.
With a larger higher flowing rear there will be a lot less manifold pressure at the same boost pressure, even running a 1.15 AR at 30psi I would expect to see less manifold pressure due to the lack of back pressure.
Just curious, if it was getting valve float in the top end, would you/could you tune around it by dropping the boost and retarding the cams?
The dyno curve looks like it gets a wiggle on a touch, maybe not significant?
It won't be floating. I run the same cams, springs and retainers and have given my setup 30 psi.
Not sure how much more boost you want to pull out of it. It's dropping to 18 psi as is.
Theoretically yes but really this is usually the last thing you do after the rest of the set up is A OK.
I think he was more leading towards that being a possible reason its like it is.
How's the water Pete?
When is it booked in for the next tune?
Hi Mark, waters all good :)
Just waiting for some other work to be finished in the shop, not much use leaving it there until he can work on it , maybe another week or 2. Not just the tune to do and I can still use the car while I am waiting :)
I've got to say I would be pretty unhappy with that boost drop.
Kind of like getting married to a hot Virgin, and then being told you have to use a condom for the rest of your life......
Yeah a bit of bummer :(
I will still take the Virgin , condom and all :)
If it's the turbo selection that is causing these issues.... Everything else is irrelevant. See what the new tuner says.
Fairly narrow minded, all you can say is its the turbo. Its rated for over 700hp ffs, if there are no other restirictions it should acheive close to that.
Can u tell me why my engine with a .82 rear housing does not have this issue?
  • Like 1
I am starting to agree with the plausibility of his theory - I wouldn't go so far as to say that's the issue, but.
You have a .82 open housing, a .84 open housing is a different beast and in most cases I would expect it to be more comparable in to a .6x open housing which would make people shit themselves if it was said that someone was going to put on a 3.2 litre aiming for 400kw+ on petrol.
When I first heard about this I thought the hotside was going to be too small and that was before I learnt it was a small divided hotside on it, I've never thought about or had to deal with a bad turbo match like this causing excess back pressure - I like to think all the things I have been involved with have quite well matched turbos and as such exhaust manifold pressure has tended to be sane and never thought about the effect on the waste gate but the more I think about it the more it makes sense. Always nice to learn something :)
Hope your right :)
I spoke to the bloke at Precision Turbo and he said it "should" not loose more than 50HP with the 3.2 . With some blokes taking these turbos up to 740HP with varied sized motors ? ?
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
