Educated Guess At The Final Tune Results
Nismo 3.2ish
Just read the last 20 pages. A lot of people have thrown different theories around with explanations. Maybe they are right or wrong, but the discussions have been enjoyable and valuable I recon, even if we are all wrong.
I'm with you, there has been some good thoughts put on here , thanks :thumbsup:
I have been reading, just not posting
Having theories is a good thing but the incorrect one should be recognised as incorrect to move focus to plausible issues so people aren't changing things that don't need to be changed
Like putting a GT42 or V cam on a car that the owner has all alone said he is after response with no shits given for top end
This setup should be at lot more responsive then it is easily beating a stock turboed GTR for response
As I said to Pete while I was there, fix what you know isn't right first before trying something you are not sure is incorrect
That has always been the plan Mick.
It will go on the Dyno to get another look at it and have a comparison Graph on the same Dyno for when the "final tune" is done :)
Then I guess he will work from there, eliminate the obvious, hopefully it will just be a tuning problem .
How do we know if the theory is incorrect if it hasn't yet been proven otherwise?
I would of thought the bigger dump/front pipe not making a difference was a good indication that the restriction is further up, ie. Turbo
The dyno graph is proof, because the the boost peaks then steadily falls away while the power continues to climb and then level out instead of falling off heavily as it would with the massive back pressure this theory implies
The theory would be under the assumption the excess pressure is only against the wastegate and not the turbine which is not the case the excess pressure is also pushing through the turbine increasing its speed and while this is happening on Peters car the boost signal to the wastegate is reducing which reduces the assistance the boost gives the wastegate spring to open the wastegate which increases the wastegate seat pressure which increases the manifold pressure and in turn the pressure at the turbine increasing turbine speed
Or is that wrong ?
My head hurts! As was mentioned earlier, the actual discussion is fantastic as no one is really saying "I know this is the issue" more along the lines of "I believe it is..." so there is no need for anyone to be getting upset about another person offering a solution. It's great that everyone is willing to offer ideas as we've all had varying levels of experience chasing various issues. At the end of the day though, it's not until a decent tuner (that has nothing to hide unlike the previous tuner seems to have...) gets the car on the dyno and properly diagnoses the tune and setup that we're going to really find out what's going on.
One thing that I also need to add is how f**king awesome it is that Peter is a 70 year old bloke with a love of the GT-R that he obviously gets a lot of enjoyment out of. Peter I take my hat off to you and can only hope that my balls don't shrivel up by the time I hit 70 and still have a passion for the amazing vehicle that the Skyline/GT-R is!
Keep up the great discussion, it's what being part of a forum is all about. A lot of you guys have a great amount of knowledge and it's great to be a part of but let's keep all knickers knotless!
  • Like 4
Or is that wrong ?
Exactly, turbo speed cant drop like that if there is huge pressure in the manifold.
Compressor out of flow could
haha, your head hurts, mine fell off pages ago :)
I reckon what Lithium said, the 0.84 split housing is probably not big enough, i had one on a 3076 and they are small in comparison to an open 0.82...
On a 3.2L motor the retarding of cams would be to try and help the top end, if they were advanced and the boost didn't fall away ( assuming deliberately done) then it would be getting pretty hot with only 98 wouldn't it? When it was previously backfiring uptop , that might of been some ignition retard from knocking up top with a small rear housing?? You said it was running pretty rich which also would suggest they were trying to keep it cool cause was getting hot in there..
Edited by AngryRB
I to like the throwing around of ideas and theories but unless there is a for and against discussion for them then anyone that reads them that doesn't know leaves thinking they are correct, I think the power of these fors is the back and fourth discussion of theories and ideas
What I don't like and why I am selective in where I post is people that think they are always right and when someone says different or questions them they throw out an insult then throw a tantrum and get upset cause not everyone just automaticly agrees with them
Or is that wrong ?
You are making a lot of assumptions as we all are.
If there was excessive back pressure and the gas speed is slowed it would have the same effect but will be more detrimental to the engine.
If the turbine is slowed the boost will drop, that's why we have a wastegate gate and the power still rises with rpm.
But the gate is open by exhaust gas in the manifold, not the boost controller so you can set the controller however u want but the turbo's rear is too small and can't flow enough to evacuate gases which results in a power ceiling and also a gradual reduction in boost.
The fact that boost had to be reduced to settle the other issues supports this to a point.
So in response to Pete questioning why he can't have more power, well that was the rationale because they can't increase boost safely.
The comment about a GT42 was merely to illustrate that people with bigger turbos don't have the issues like he is having.
But he loves the response of his set up, no one is telling him to change it, he just asked many 'why' questions and theories we share and hopefully JEZ can sort it out for him, and when they do we can learn something.
I would be a great car to drive regardless.
  • Like 1
I think I must have given the wrong impression about power, everyone questioned the power I had, I did not have an expectation of much more than what I ended up with , I had spoken to the builder and he said it would be around 400kw and it was, 386.9kw.
But I questioned where the power is and why it drops off. I mean you cannot get any thing spinning at a 5k or 6000rpm launch, a little slip and thats it ,( I do not want to disappear in a cloud of smoke, but ?) I guess it is because the boost has already started to fall off at 4500rpm , maybe also because of better 4WD traction and good rubber, I thought 380KW would be mad :huh:
If it is a bolt on problem, I can change whatever is needed.
But the main thing is to get it in the shop and see how it goes with the mods it has now and see if anything shows up on the Dyno.
He has also used the PT6262 on his stock RB26 and is at full boost around 4300rpm , so he should have an idea how to get the best out of it.
    • Near 12mths since the last update apologies.  Car is back running and driving.  Have had a few runs at the drag strip also with a bit of success.  Managed to run tje cars PB with a 10.88 @139mph with a 2.0 60ft.  I have a stock 8hp converter and it's definitely too tight for my setup. But it drives on the street phenomenal. So happy to have converted from the sequential. Has made the car enjoyable to drive vs a what felt like a chore with the sequential.  Looking a at few different options for converters waiting for some feedback from SDE if he can do one for me.  Still a few minor things to work out regarding finalising torque reduction, I have it working but needs to refining.
    • I honestly wouldn’t bother with this. They don’t hold up under any serious strain. Get the Blackline (Chinese fake Quaife) if anything, as it’s reported to perform pretty well.
    • For future reference, I believe all that Amayama does is act as a middleman between you and Nissan. Go to your local dealership, ask nicely for a parts account (I get 15% off with mine) and you'll get better pricing. Cheers,
    • Hi guys, I have a 2005 V35 skyline with the vq35de.  It is a drift car and has been stripped, its now running a standalone ECU and a body harness. Dash everything has been changed to a digital dash controlled by ecu.  The vq35de has been great, very reliable but wanting more HP atm the 35de is making 228rwhp. I'd like to be making about 350rwhp. From my research it looks like a vq25det lightly modified could be a good engine to swap in. I understand the CD trans will bolt up right to the vq25det with a 35de sump used.  My only issue is a wiring harness/ecu to control the vq25det, from what i've found the ecu is a lot different to the vq35de so my plugin for the 35de will not work. Is there any potential to use the vq35de wiring harness and modify as necessary to retain the plugin ecu?  Keen to hear what you guys think, or am I best off to chuck on a cheap turbo kit on the 35de and see how long it lasts.
    • Oh sorry Justin! I was racking my brain trying to remember names, not sure why I associated “Adam” with 7tune! I’m good, been away from Skylines for over a decade, got family and kids now. Just getting back into owning a 32 but it’s a whole different world now… tax is higher and tech is better.
