Thanks mate, looks great!
Thanks to Kurt and Paul as well :wub:
I should be able to get a few stone chips, sand, mud and crap all over it after all this rain, running down the old road today, lol
See you blokes later :cheers:
It car came up great, only trouble is I have to wear sunnies outside the car, great job but mow I have to try and keep it looking the same , pain in the arse , lol
Had a quick run when the car was dropped off yesterday and could feel the difference without smashing it hard.
I went for a run this morning and it is a different machine to drive , first I gave it some up to from idle 7500 and it felt like it was hard all the way after 3200 and got there pretty quickly, felt great.
Then I did some changes at 5000rpm and it was on boost through 1,2,3,4 and 5th had to stop
Next I did the same a 4000rpm 1,2,3 and 4th to see what happen, it was just about ready to fly in another 300rpm from each change, mad!
You can dive it anywhere in 6th gear in a 60 , 80 or 100kph zone without changing back on any hill , the only time I had to change was on the 35kph bends going up to a step incline , that torque is just so good in a street car , especially if you want to relax a bit
I would say it is very close to 900rpm better while driving it in any gear if you want to get it going. it really starts to get going at 3000 and hard just after that :wub:
From my experience it smashed the 6266 everywhere as a driving experience.
Happy camper, you bet , it is a great car to drive at any speed and just feels alive everywhere
Worth every cent spent! ( that's for you Hadouken :) )
  • Like 5
26 minutes ago, Piggaz said:
Killed your own thread, Pete. ?
The End...ish!
Not sure how it lasted this long mate, lol
If I knew how I killed it , I could have done it ages ago and made some blokes happier ,  Mafia he said it would not last 5 minutes on the first page and probably get shut down from lack of interest, they were both close calls but it dodged the bullets, haha
Has been fun , so all good :)
  • 7 months later...
Well I think this is the best down low torque I can get without pulling the head off and that's not happening .
E85 30 Nov 2017.pdf
Edited by Nismo 3.2ish
Must drive good Pete.
You make what a what a “responsive twin turbo 2.6 Litre” at peak power... what you do at 4200 RPM ?.
Thats NA shit!
That laggy single turbo.
Here is a before and after graph ?.
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
