  • Replies 70
You'd be crazy to not have them replace the seals when the gears are off.
Removing the cover is easy, then you have to reset the timing cos you have to take the cas off.
Oh man. Can't believe I didn't actually rad the thread correctly.
A clear cam cover is something very special indeed. Especially one that could stay clean!
These questions aren't "forced induction" questions..
Use the correct section ie general maintenance
Great thanks for your input.. not
And its obviously a waste of money.
You drive a stagea lol
I'm loving the idea of clear cam covers. That wording, plus the question of whether it will stay clean on the inside was worth a laugh.
Timing cover, now that's whole 'nother biscuit.
Wow another one with a constructive comment thanks you obviously know everything high five..
Lol you drive a stagea. .
+25hp for the wank factor?
Seems to be a lot of wank factor on this forum. Lol
Thanks for that I'll make sure they replace the seals..
Yes it should stay clean if inside your timing cover is clean and your cam seals don't leak. It would only be 3/4 bolts to take it off.
Thanks again I appreciate the civil and constructive reply
Are you better than me cos of the car you drive?
If you think that's the case I'm truly sorry for you that your life is so basic and materialistic.
Really. Its sad.
The way you react to replies on here is hilarious, so don't go changing.
Someone might spoon feed you with exactly what you want to hear sooner or later.
Yea Good one
If your gonna comstantly ask stupid questions might as well do it in the right
Section
Lol sorry genius I didn't mean to offend you by my question. . It's obviously well below your intelligence levels.. If you like dishing insults how about a nice simple reply for you superior brain.. 'gonna' isn't a word ..
Really. Its sad.
Ow I'm sorry you can dish it but can't take it .. no prob.. I'm sorry and yes a simple constructive answer to the question is preferred. . If you want to play games and consider yourself funny join a comedy club or a funny forum .. ??
Man.
You come on here asking people to help then act like this?
Just throw money at your chosen shop and get some shit result. But a clear cover for wank factor.
Good luck with it. Then you sell the car for a huge loss.
How would the inside of a cover get dirty? Well one way would be a leaking camshaft seal, which only a lunatic wouldn't replace when they have the gears off a unknown km engine. Or the crank seal. Or the water pump.
  • Like 1
Not offended, just surprised by your complete lack of common sense,
mechanical knowledge and inability to use the search function.
Probably your parents fault more then anything.
  • Like 2
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
