Hi everyone.
So my r34 gtt has had a gt3076 56trim with a .63 internal housing for some time now. I never can flog it due to the horrible boost creep. not to mention the kinda shit power from that turbo at that psi.
So to fix the issue i got a .82 housing with a ported 37mm internal gate. Drove it today and it still creeps to about 1.3bar. but holds there where before it would keep going until it started to lean out (fart, crack ect.)
this turbo is from gcg and the housing, i use a apexi avc-r controller, standard manifold (mild port), split dump from gcg, 3inch front pipe (i Think) to apexi hi silent back exhaust, no cat.
So basically can someone explain or possibly rectify this issue (which seems to be common).
if they are selling these things for rb25 they must have some form of boost control.
I'm to far gone for a external gate as it defeats my original intention.
thanks
Does make sense though seems unlikely, What's your thoughts on the gt3076 was originally for external gate only, but they sell IW for more bolt on options but no one is aware of the boost creep issue, made to fail?
something someone just told me?
Edited by Jaydenk92
Zebra is correct!!!
change your dump pipe to an open mouthed one and problem solved... nothing wrong with gt3076's...the 0.82 internal gate has zero problems with boost creep, 0.63 can have some issues
Edited by AngryRB
Those split dump pipes are known to have these issues man.
Although if you feel like a power upgrade too you should send your rear housing to Scotty on here to get an external gate welded on. Atmo from the wastegate + big external gate = more smiles
I looked very hard at their GT30 integral dump and opted to have an open mouthed dump/front pipe made .
If you look at the inlet of the waste gates bypass its round where the turbine housing isn't , maybe convenient to make with a hole saw but questionable functionality . Hard to believe there wouldn't be a pressure rise here and anything that does this downstream of any waste gate can effect its performance .
I bought an XR6T turbo side GT30 IW flange plate from Carlton Mufflers because theirs is thick and thick is good when you have to weld to it .
Kirawee Mufflers made the front pipe in I think 3.5 inch tube and formed a gusset for the gate outlet section . I never have creep issues and with the same housing as yours . 1 bar large can actuator and the brain box does boost control .
IMO except for big budget race apps where everything is flow tested split dumps are more trouble than they are worth . If you really want to separate the two exhaust streams and the turbine housing casting doesn't have a short divider build one into the flange plate .
If you are really concerned about pressure build up behind the T housing then use larger bore tube here and neck it down at or behind the cat . My system is 3.5 inc the cat and its conical outlet was made the reducer to 3" . My exhaust is higher flowing and noticeably quieter than the Japanese name brand POS it replaced .
A .
dw man, 1.3bar is perfect :)
also throw that split dump into the bin.. it's more of a headache than anything else.. the wastegate flapper probably isn't able to fully open and causing all the issues, but if it's creeping and staying steady at 1.3bar then that's good...
so are you guys saying that the flapper fouls out onto the dump pipe?? I also notice that i have a split dump, yet i don't have a split dump gasket fitted AND the housing has a gap about 4mm deep in the middle which would allow gases between the wastegate and turbine thus DEFEATING THE FREAKING PURPOSE of a split dump being used. which i believe will cause a pressure yes????
also, disconnected my ECB (12psi spring) found it would hold 1.05 bar in second, then creep to 1.25bar in 3rd. so its not as bad but still creeps no questions about that. So my ebc isn't the issue. i believe its better as the ebc ramps boost up higher before allowing the gate to open.
you can test whether the flapper is fouling on the dump by disconnecting the actuator and seeing for yourself. Might be worth a try but it sounds like you have to change the dump out
Would you know, i tried that a sure shit it hits, the flapper travels like 35deg before hitting, FOUND THE PROBLEM :) :). even though i bought a whole new housing at least it what be as restrictive
  • Like 1
I spoke to gcg and he said it might be a case where my engine flows a bit healthy at which the IW isnt large enough to control boost. Becuase he said most application the flap only opens about 30-40deg. Which i think sure maybe for 12psi with standard exhaust lift. But not tomei type b cams and 18psi i think not.I checked what 30-40deg looks like and the flapper is still directly in front of the flow direction which would cause some turbulence. So does anyone know if a open bell for a 6 bolt rear is available???? anywhere??
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
