  • 3 weeks later...
  • 3 weeks later...
On 30/10/2019 at 10:28 AM, z00key said:
What he means is Thanks bro but I got some but I appreciate you looking out
Geez it's a bit lonely in here.  I'm on the P.C. I downloaded the tapatalk app for the android phone but it won't let me sign in or do anyting at all really. Any one else had the same issues?
I think taoatalk is gone man
  • 1 month later...
Oh hai Tab, very long time no see.
The lady is old now :(  her face is rapidly turning grey.
She is also about 70kg
and now has a greyhound as her best mate
Crikey 70kg! Phil and I have two Huskies and the fat one is 25kg.
I dropped by here the other day looking for an old video of driver training that I've lost and still recognised some names!
I had to sell my car back in Feb 2016 due to bubs #1. Still miss that car ?
Sup everyone, yep still alive, who would have thought dad lyfe was so demanding lol, anyway I have a question I remember a while back there are a few guys here that ride bikes and am thinking to get myself a dirt bike, have about a budget of 2k, reckon that would get me something for a bit of casual fun, also anyone I can call on to help me inspect some bikes with as not ridden a bike in about 15 or more years, and I dont think that they are steam driven anymore ha ha, oh and if u have a bike am keen to go out riding to?
you missed me by about 18 months. Off the chook chasers now and on the road. Currently riding a Royal Enfield Interceptor, which is pretty fun.
For 2k what ever you end up with, its going to teach you a LOT about fixing bikes :P Avoid anything KTM (fantastic powerful bikes, fragile aF and will cost the earth to fix)
If you want to ride it to and from the bush, try not to go under 400cc.. Suzukis are good, DR-z400 and DR650 (if you dont mind it a bit agricultural) but goes forever. You just need to do a fair bit to them for the bush, so keep an eye out for ones with lots of bolt ons. The owner, he knows ;)
Or just get a postie bike, they are fkn hillarious fun, there is a whole world of bolt on bits available, and its got no clutch so you can teach your missus to ride it.
Its ugly AF, but an absolute diamond in the rough, (soooooo much styling potential) but if I was going to buy another one, this is what I would look at first
https://www.gumtree.com.au/s-ad/kelmscott/motorcycles/kawasaki-650/1238483936
WR's are good bikes,  but damn high maintenance to keep them running.
They also don't have a cush drive in the back wheel,  so if you ride them on the road it destroys the gearbox pretty quick,  so I would avoid a motard  version like the plague.
But i have a KTM. 300exc, real widow maker. The new 350's are awesome bikes.
Stay away from anything honda, the older kawasakis are not too bad. i have always had 2 strokes, but have recently picked up a wr250f 4 stroke, for me being 100kg it struggles a bit.
Doing the same as Dale now and looking out for a Thruxton to ride on the road
@Stinky Rooster I never knew you were still kicking around on here. I just came for a quick interjection ..
There was an old Sci Fi book ( I mean way old ) where basically you could jack different "shards" I think they were called into your brain and suddenly you had a wealth of knowledge about a certain subject.
I am currently preparing the block and cleaning out all the old shitty gasket crap , got 1/2 an idea what I am going but I just thought , what if you could just automatically be a guru at any given subject that's on hand? And no, I have not had any illicit substances or drank a bunch of booze lol
I just want to know how good the surface of the block needs to be to ensure the new head gasket has every chance of success.
Currently working on it gently with an angle grinder
J/K!
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
