I'm almost scared to ask.... But what happened?
Had a hernia op, thought why not get the snip at same time.
Ball bag has inflated like a hot air balloon and is trying to pull my guts out when I move.
Lurker Steve here. This month:
I blew up my BMW (bottom end).
I got fired. [emoji26]
I did my back on the long weekend (too much picking up small children incorrectly).
Next month cannot be worse.
Oh wait. Getting a vasectomy in two weeks. [emoji849] I'm praying it doesn't hurt.
I had a vasectomy 14 days ago and I’ve only just started walking. I spent 13 day/ nights on the couch and couldn’t sleep in my bed and I’ve still got a purple grapefruit between my legs
I also had a hernia removed but that caused almost no grief
I can’t overstate the importance of tight underwear, and NSAIDs if you swell up. Im using Panadol rapid 3x during the day and Celebrex morning and night.
I’m jealous of those who are fine 24-48hrs later. Good luck but next month might be worse
Oh no. That's not what i want to hear. [emoji43] Did something go wrong or is it just how it sometimes goes?
I've been told 5-7 day recovery max.
I'm glad to hear you're on the mend again.
Went to see surgeon on 7th day. He said I was just unlucky that I blew up but most of the pain was my fault for wearing loose underwear one day even if I only walked a short distance
I wasn’t sore for the first 48 hours but then each day got worse.by day 7 I was in tears to walk. I was sore cos of cracked skin from excessive swelling but most of the pain came from a ligament between my hip and leg tearing from the weight hanging off it.
It seems to be common to swell up but it’s usually pain free.
  • Like 1
Ok... I'm hoping that's not me. My surgeon suggested I'll be able to get back on my bike within a week. Maybe I'll just push that back. Regarding underwear (sorry to lower the tone all), are normal briefs/y cuts ok or should i be getting something else?
    • So I put it to 3bar (43.5psi) while priming. It stays at 43.5~ as I crank shakes slightly. Ive also tried dropping pressure to see if that changes anything. I replaced the fuel dampener because I was troubleshooting the system along with the stock FPR (swapping them one by one to rule them out). But i only got up to changing the dampener and it started running again. Injectors are stock second hand. I did a bench test on both my original ones and the secondhand ones. The second hand injectors I have in the car now spray slightly stronger than my original injectors.
    • I knew Andy from about then, it did some cool stuff. By 2005/2006 era, he also implemented closed loop ignition timing tuning. In 2004 it was pretty cool, being with him when he was doing automated fast self learning tuning!
    • Im No tuner but…. im running a 25det with north of 600wkw at 9000rpm e85 and water meth. G40 1150 on 32psi. Having a real built head will flow a crap ton more power but you being stuck at 7600 won’t be helping at all, throw all the boost you can and nothing will happen. Solid lifter and 9000rpm is the only way,  I have built my motor 3 times, not from engine failure but more along the lines of my failures in not understanding engine parts better, basic phrase to help, “block hold power”  “head make power”
    • What's the fuel pressure while the car is cranking? Curious, why did you replace the fuel damper? What injectors are you using, are they brand new?
    • I think it's terrible value, it should be half that price IMO. And I'm known as someone who will unironically suggest the GTIII-SS on the RB26 if you have very specific requirements. The GCG RB25DET "hybrid turbo" is 1/3rd the cost of this GTIII-RS kit and sounds like it should fit with zero modifications. Talk to Hypergear as well, maybe they can do something that fits your requirements.
