I was going to sit and study for exams, but then I thought that's boring so I changed the coil packs. The car is so much smoother, idle's smoother and quieter and revs quicker too. Another thing ticked off the list.
I havnt forgotten about this thread of the car, im now working full time during the week as well as part time on the weekends. I want to work on the car but got no time....hopefully I can put aside some time to keep working on the car.
Also my first DIY got approved so have a look, give me feedback :rolleyes:
Small amounts of time on my hands now. So I decided to add some rice, therefore added some LED lights in the footwells. They turned out pretty well actually. Not sure if a tutorial exists but if someone wants one, ill write one up...well I'll probably write one up anyway.
Edited by shubby0901
  • 3 weeks later...
Thanks guys.
I had plans to get an exhaust made before christmas but the muffler I want was not available anywhere, so now I will probably get it done around the end of January due to work and travel before that.
So over the weekend I attempted to fix the passenger side mirror as it doesnt fold in. After pulling the whole thing apart and thinking the gears are jammed, I pulled them out cleaned them, bought new grease and greased them up and reinstalled them...only to have it still not work... :yucky:. Mirror had to be reinstalled as I need to drive to work tomorrow. On the hunt for a mirror which has a working folding mechanism to swap it out now.
Greased up gears:
In the process of removing the mirror, I smashed the tweeter when I didnt realise it as hanging and closed the door. Luckily it was only the casing so I thought what better excuse to properly mount the tweeters.
Went from this (ignore the missing door card)
24fc5ddf-17f6-4fe7-ab2d-59f8a6c9e719_zps
To this:
6e97d29e-c3ff-4fa1-8190-7d271541c798_zps
I call it a success and it makes the interior look so much nicer.
Hey mate - You will find the issue isn't the gears rather its the contacts in the switching mechanism in the mirror. Happened to me and I used this guide to fix it:
http://www.sau.com.au/forums/topic/93178-r33-electric-side-mirror-repair-s2/
Shortly after I fixed the passenger side, the drivers side went and I haven't been bothered to fix it lol.
GL - Tweeters look nice like that
  • Like 1
Hey,
Yeah I thought this initially but when the switch is pressed the motor make noise and both if the mirror is open or closed, the whole system doesn't work, anyway i ran out of time to try the contacts solution so maybe next time.
  • 1 month later...
Got the car back. Exhaust sounds awesome!!
Specs: Catback Stainless Steel 3.0" with Varex Twin Tip muffler connected straight to battery.
I will record a video and upload it soon.
7c2e8e96-28b7-4adf-bb9d-3c05ea2461d2_zps
  • Like 3
The twin tips look pretty neat on the car. *thumbs up* So simple yet so nice.
Thanks man.
Following your thread too. Love the front bumper, skirts and pods on your car. #Goals haha
  • Like 1
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
