I was going to sit and study for exams, but then I thought that's boring so I changed the coil packs. The car is so much smoother, idle's smoother and quieter and revs quicker too. Another thing ticked off the list.
I havnt forgotten about this thread of the car, im now working full time during the week as well as part time on the weekends. I want to work on the car but got no time....hopefully I can put aside some time to keep working on the car.
Also my first DIY got approved so have a look, give me feedback :rolleyes:
Small amounts of time on my hands now. So I decided to add some rice, therefore added some LED lights in the footwells. They turned out pretty well actually. Not sure if a tutorial exists but if someone wants one, ill write one up...well I'll probably write one up anyway.
Edited by shubby0901
  • 3 weeks later...
Thanks guys.
I had plans to get an exhaust made before christmas but the muffler I want was not available anywhere, so now I will probably get it done around the end of January due to work and travel before that.
So over the weekend I attempted to fix the passenger side mirror as it doesnt fold in. After pulling the whole thing apart and thinking the gears are jammed, I pulled them out cleaned them, bought new grease and greased them up and reinstalled them...only to have it still not work... :yucky:. Mirror had to be reinstalled as I need to drive to work tomorrow. On the hunt for a mirror which has a working folding mechanism to swap it out now.
Greased up gears:
In the process of removing the mirror, I smashed the tweeter when I didnt realise it as hanging and closed the door. Luckily it was only the casing so I thought what better excuse to properly mount the tweeters.
Went from this (ignore the missing door card)
24fc5ddf-17f6-4fe7-ab2d-59f8a6c9e719_zps
To this:
6e97d29e-c3ff-4fa1-8190-7d271541c798_zps
I call it a success and it makes the interior look so much nicer.
Hey mate - You will find the issue isn't the gears rather its the contacts in the switching mechanism in the mirror. Happened to me and I used this guide to fix it:
http://www.sau.com.au/forums/topic/93178-r33-electric-side-mirror-repair-s2/
Shortly after I fixed the passenger side, the drivers side went and I haven't been bothered to fix it lol.
GL - Tweeters look nice like that
  • Like 1
Hey,
Yeah I thought this initially but when the switch is pressed the motor make noise and both if the mirror is open or closed, the whole system doesn't work, anyway i ran out of time to try the contacts solution so maybe next time.
  • 1 month later...
Got the car back. Exhaust sounds awesome!!
Specs: Catback Stainless Steel 3.0" with Varex Twin Tip muffler connected straight to battery.
I will record a video and upload it soon.
7c2e8e96-28b7-4adf-bb9d-3c05ea2461d2_zps
  • Like 3
The twin tips look pretty neat on the car. *thumbs up* So simple yet so nice.
Thanks man.
Following your thread too. Love the front bumper, skirts and pods on your car. #Goals haha
  • Like 1
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
