jeez. Just kiss already.
Doesnt matter which way you put it, a equal length front pipe is the best sounding RB26. But if you go single then it sounds mental on its own.
Some say a equal length is beneficial to allow the gasses to flow evenly out to the tailpipe and inturn helps with shuffling. I can definitely say that a equal length front pipe helps with shuffling. My midori front pipe shuffled like a fair bit up inclines. But with the mines front pipe I do not experience the same level of shuffling.
But biggest point here is sound.
The end.
That is not the purpose of this topic and if you go and google I am sure you will find many more theories on the differences.
They hug the body VERY well. I've never bumped them on the ground. They generally won't do an exhaust unless they have THE car they're going on... So they can get the fit spot on. Not sure if that's changed but that was the story a few years ago.
  • Like 1
thanks Piggaz they said they could send me one I just wanted to see if anyone in sydney could make one just as good if not better so I can make sure it fits snug
The unequal length twin 3 inch system on the 33 gtr I have here sounds awesome, if only the 3L bottom end didn't make it sound like a VL.
You seriously think a few extra inches in a front pipe will make it sound any different?
Yes,
http://youtu.be/6dSrNZK6ogc
  • Like 1
for an extra couple of bucks, can't hurt?
You made them?
  • Like 1
Yes,
Lol, you believe a youtube sound clip? That is obviously not just swapping the front pipes. It's the mufflers that change the note, not the pipes.
I agree, it makes little difference to the price, although there are many more bends and you will be sacrificing flow for this equal length nonsense. I like to tuck my systems up, not have them hanging down lower. Each to their own I guess.
You made them?
This was Daz's car, he already had a twin 3 inch system, I am just making it work with the taller block.
I have done a few twin 3 into 4 inch systems, usually tapering back to 3.5 at the mid muffler.
My car came with the usual unequal length front pipe. I changed it to an equal length one (no other changes to the car) and the sound changed (used to sound like my old neighbour's 6cyl BMW, now sounds like a "real GT-R" :P).
  • Like 1
If some of you gtr owners are that purist, perhaps the stock exhaust is the go? I am sure Nissan will still have a few in storage.
The unequal length sidepipes on the Gibson GTR I worked on had a beautiful note at 8000 revs. :P
  • Like 1
Fact is, unequal vs. equal length front pipes produce different sound. I know I heard it on my car. Doesn't mean it sounds any less meaner, just different.
Here's another youtube vid.
Performance wise? probably no difference. Practical wise, unequal is better, my equal length hangs pretty low (lowest part of the car) and has copped some dents.
I am terribly sorry that I used evidence to give you an example. Or maybe the fact that I also changed front pipes to equal length ones and the note changed of the exhaust. Oh and didn't touch the timing nor manifolds. Now you are calling me simple minded? Give me some credit at least.
But I don't know why we are arguing. You are clearly wrong and now it seems you are just hell bent on being right.
That is not the topic of discussion here.
  • Like 1
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
