tridentt150v Posted July 9, 2015 Share Posted July 9, 2015 I use a 10w solar panel and PR1210L regulator [cost approx $80-100). I made up a small plug at the back up under the number plate and run a wire to the battery. I don't disconnect my battery or do anything like that. The solar panel is mounted on the carport roof and the wires for it come down the column and exit just about adjacent the the rear of the car. So simply drive in and plug in. Its a '98 and the battery is in the boot but you could make it work for any position. Not quite on topic, but sort of relevant. 1 Link to comment https://www.sau.com.au/forums/topic/457967-using-trickle-chargers/page/2/#findComment-7565481 Share on other sites More sharing options...
Hadouken Posted July 9, 2015 Share Posted July 9, 2015 That's a nifty setup. You can pretend you have a electric car. Link to comment https://www.sau.com.au/forums/topic/457967-using-trickle-chargers/page/2/#findComment-7565653 Share on other sites More sharing options...
tridentt150v Posted July 10, 2015 Share Posted July 10, 2015 Yeah, just as long as I tow my carport around......could be a challenge though, carport has tile roof and brick columns Link to comment https://www.sau.com.au/forums/topic/457967-using-trickle-chargers/page/2/#findComment-7565871 Share on other sites More sharing options...
Duncan Posted July 10, 2015 Share Posted July 10, 2015 awesome setup, I think I'll copy it for the ute that lives outside. those cheapy solar chargers do not work well with good quality (eg AGM) batteries because they don't regulate properly, so while the $80 seems expensive it is actually pretty cheap for that sort of setup Link to comment https://www.sau.com.au/forums/topic/457967-using-trickle-chargers/page/2/#findComment-7565911 Share on other sites More sharing options...
GTR-N1 Posted July 13, 2015 Share Posted July 13, 2015 I claim no responsibility for this... Pat Callinan had the RedArc Relay Management System installed along with the secondary gel battery. And I'm just the beneficiary of buying her. Lucky me. Link to comment https://www.sau.com.au/forums/topic/457967-using-trickle-chargers/page/2/#findComment-7566824 Share on other sites More sharing options...
Hadouken Posted July 13, 2015 Share Posted July 13, 2015 WOW! Now that is practicality!!! 1 Link to comment https://www.sau.com.au/forums/topic/457967-using-trickle-chargers/page/2/#findComment-7566880 Share on other sites More sharing options...
tridentt150v Posted July 17, 2015 Share Posted July 17, 2015 I probably should add that I have an Odyssey battery in mine. But the solar changer set up should work with any sort of battery..........but pls don't forget your solar panel regulator otherwise you will cook the battery cos on a warm summers day they can run as 20 volts and the reg. keeps this to 12-14 volts. 1 Link to comment https://www.sau.com.au/forums/topic/457967-using-trickle-chargers/page/2/#findComment-7569076 Share on other sites More sharing options...
r32-25t Posted July 20, 2015 Share Posted July 20, 2015 So if I go into jay car I should be able to get most of the things to create this set up? Link to comment https://www.sau.com.au/forums/topic/457967-using-trickle-chargers/page/2/#findComment-7570445 Share on other sites More sharing options...
tridentt150v Posted July 20, 2015 Share Posted July 20, 2015 http://www.ebay.com.au/itm/Solar-Panel-12V-10W-with-Alligator-Clips-Battery-Charger-GENUINE-SUNTECH-CELLS-/181254244444?pt=LH_DefaultDomain_15&hash=item2a3398485c http://www.ebay.com.au/itm/PR1210L-12-VOLT-10AMP-AGM-GEL-SOLAR-PANEL-REGULATOR-DEEP-CYCLE-BATTERIES-BATTERY-/321231818550?pt=LH_DefaultDomain_15&hash=item4acae88f36 Then wire and either alligator clips or a plug for your battery end. As an aside I use this same setup on my minidumper and excavator as well. They can be parked out in the paddock for days at a time and in the cold weather that is death to batteries - but with this setup, I turn the key and they go, always charged and ready. Let me know how you go. If you need any help or more info let me know in msg's and I should answer quicker - cos I get an email notification. Link to comment https://www.sau.com.au/forums/topic/457967-using-trickle-chargers/page/2/#findComment-7570485 Share on other sites More sharing options...
tridentt150v Posted July 20, 2015 Share Posted July 20, 2015 Terry that setup has to be for a second battery and fridge, its way overkill for just the battery alone. You'd need a very good regulator for that one as well cos on a hot day it would be thumping some amps. I'd also check that it doesn't discharge overnight, a lot of the bigger solar panels don't include the blocking doide so what you make during the day gets lost at night or in dark sheds/carparks etc. Just check your voltage after a sunny day and then again in the morning, if its dropped away heaps it means one of two things your battery is cactus or the solar panel setup is discharging. To check that disconnect your battery after a sunny day and again check the voltage if its down heaps its the battery, if its not then its the solar panel set up. A blocking diode costs around $5 at a guess and is an easy fit for just about anyone but needs to be orientated correctly. And by dropping away overnight, I'm talking from 13 volts down to say 8 volts. Discharge is pretty severe when it happens - thats for your size panel.If the panel is smaller and discharging the rate may be a bit smaller say down to 9-10 volts. Link to comment https://www.sau.com.au/forums/topic/457967-using-trickle-chargers/page/2/#findComment-7570490 Share on other sites More sharing options...
r32-25t Posted July 22, 2015 Share Posted July 22, 2015 http://www.ebay.com.au/itm/Solar-Panel-12V-10W-with-Alligator-Clips-Battery-Charger-GENUINE-SUNTECH-CELLS-/181254244444?pt=LH_DefaultDomain_15&hash=item2a3398485c http://www.ebay.com.au/itm/PR1210L-12-VOLT-10AMP-AGM-GEL-SOLAR-PANEL-REGULATOR-DEEP-CYCLE-BATTERIES-BATTERY-/321231818550?pt=LH_DefaultDomain_15&hash=item4acae88f36 Then wire and either alligator clips or a plug for your battery end. As an aside I use this same setup on my minidumper and excavator as well. They can be parked out in the paddock for days at a time and in the cold weather that is death to batteries - but with this setup, I turn the key and they go, always charged and ready. Let me know how you go. If you need any help or more info let me know in msg's and I should answer quicker - cos I get an email notification. awesome thank you will definitely be trying this for my self Link to comment https://www.sau.com.au/forums/topic/457967-using-trickle-chargers/page/2/#findComment-7571372 Share on other sites More sharing options...
GTR-N1 Posted July 23, 2015 Share Posted July 23, 2015 Terry that setup has to be for a second battery and fridge, its way overkill for just the battery alone. You'd need a very good regulator for that one as well cos on a hot day it would be thumping some amps. I'd also check that it doesn't discharge overnight, a lot of the bigger solar panels don't include the blocking doide so what you make during the day gets lost at night or in dark sheds/carparks etc. Just check your voltage after a sunny day and then again in the morning, if its dropped away heaps it means one of two things your battery is cactus or the solar panel setup is discharging. To check that disconnect your battery after a sunny day and again check the voltage if its down heaps its the battery, if its not then its the solar panel set up. A blocking diode costs around $5 at a guess and is an easy fit for just about anyone but needs to be orientated correctly. And by dropping away overnight, I'm talking from 13 volts down to say 8 volts. Discharge is pretty severe when it happens - thats for your size panel.If the panel is smaller and discharging the rate may be a bit smaller say down to 9-10 volts. I really appreciate the time and effort you've spent on my system. Having been installed by Pat Callinan I'd be interested in what ARB has to convey to me about this Redarc Management System wrt how the regulator operates etc. I only have a bit of knowledge about chemistry but bugger all about electricity. Link to comment https://www.sau.com.au/forums/topic/457967-using-trickle-chargers/page/2/#findComment-7572462 Share on other sites More sharing options...
tridentt150v Posted July 23, 2015 Share Posted July 23, 2015 Oh I should have looked a bit harder the regulator is there next to the battery. Being a good one plus the set up being installed by ppl that know what they are doing I'd say your fine. But its for a fridge or some such for sure, you could put a good quality inverter on that and use power tools as well - either directly or to charge 18v batteries via the 240v charger. We do that with some of our work vehicles. Anyway having that sort of system is a definiate bonus, you could go 4wding and trekking across the centre with that set up. 1 Link to comment https://www.sau.com.au/forums/topic/457967-using-trickle-chargers/page/2/#findComment-7572526 Share on other sites More sharing options...
mattis96 Posted July 26, 2015 Share Posted July 26, 2015 I had a ctek trickle charger on mine for years, left both terminals connected due to alarm. Never a problem. Until the charger died with out me knowing and ended up stuffing the d34 optima Link to comment https://www.sau.com.au/forums/topic/457967-using-trickle-chargers/page/2/#findComment-7574628 Share on other sites More sharing options...
djvoodoo Posted July 27, 2015 Author Share Posted July 27, 2015 I've ended up using the Jaycar charger on a digital timer i bought from Bunnings. Turns on every 2nd day for 45 mins. Has been going good now from when i started this post. P.S i have an Optima battery too Link to comment https://www.sau.com.au/forums/topic/457967-using-trickle-chargers/page/2/#findComment-7575185 Share on other sites More sharing options...
Dose Pipe Sutututu Posted July 30, 2015 Share Posted July 30, 2015 buy a CTEK charger, they're designed for this. All 4WD, Boating and Caravan enthusiasts use them. Fantastic unit. 1 Link to comment https://www.sau.com.au/forums/topic/457967-using-trickle-chargers/page/2/#findComment-7577151 Share on other sites More sharing options...
silviaz Posted March 13 Share Posted March 13 Which trickle charger does everyone use? I'm going on holidays in the future, and last time it was left for a couple weeks off twice per time, and don't want to keep doing it to damage my battery so looking to have something hooked up to the battery which connected to the car, as I need to keep my immobiliser system on. If the battery goes flat it will mess up my security system (already happened once) I was looking at the following, so can have someone turn it on every couple of days and run it overnight then turn it off) https://www.supercheapauto.com.au/p/noco-noco-genius-5-battery-charger-6v-12v-5-amp/648987.html?cgid=SCA01060203#srsltid=AfmBOoq4kzQgrm1YHSZT0DzaCwVwwOcevgu0TSDcUvrNeOqI-0S5xJ1C&start=1 https://www.supercheapauto.com.au/p/century-century-cc1206-xli-12v-1-3-6a-9-stage-battery-charger/693006.html?cgid=SCA01060203#srsltid=AfmBOoq4kzQgrm1YHSZT0DzaCwVwwOcevgu0TSDcUvrNeOqI-0S5xJ1C&start=30 though these don't say anything about trickle charging, don't want it to overcharge the battery. Link to comment https://www.sau.com.au/forums/topic/457967-using-trickle-chargers/page/2/#findComment-7998527 Share on other sites More sharing options...
Duncan Posted March 13 Share Posted March 13 I have a projecta one. A proper trickle charger can be left attached 24x7, that's what the trickle bit is about. 1 Link to comment https://www.sau.com.au/forums/topic/457967-using-trickle-chargers/page/2/#findComment-7998530 Share on other sites More sharing options...
GTSBoy Posted March 13 Share Posted March 13 C-tek here. MXS 5 IIRC. It's the tits. 1 Link to comment https://www.sau.com.au/forums/topic/457967-using-trickle-chargers/page/2/#findComment-7998532 Share on other sites More sharing options...
silviaz Posted March 13 Share Posted March 13 18 minutes ago, Duncan said: I have a projecta one. A proper trickle charger can be left attached 24x7, that's what the trickle bit is about. Yup, just wanted to make sure I found one that was a trickle charger and not just a battery charger, not sure if there is a difference there but assumed there was, was why I was worried about overcharging. Link to comment https://www.sau.com.au/forums/topic/457967-using-trickle-chargers/page/2/#findComment-7998534 Share on other sites More sharing options...
