The parts I need to fix the oil leaks have finally arrived and I can start moving forward with the project again
In there is the speedo drive o-ring and seal and also a new power steering hose, will be fitting them as soon as I get some time (hopefully this week) and get the car back on the ground to get that exhaust sorted out
Awesome project so far mate. Look forward to your posts!
thanks mate, unfortunately at the moment it's little job that must be done before I can get back into the bigger jobs
Friday I fitted the power steering hose and the seals for the speedo drive, but for the awd piston in the back of the box there is no seal,
So I pulled it out and ran a bead of sealant around it and put it back in
I then filled the fluids back up and started the car to bleed the power steering and left it up on the stands. Im going away for a week so will leave it up there and check for any signs of leaks when I get home, it should all be good and I can move onto other things
I'm back from my holiday and went out to the garage cause the car was left on the stands and its dry under there, so the oil leaks are all fixed and I can move on
While I had it in the air I knew it required new castor rods cause it would squirm under brakes and really didn't feel safe at all. I had a set sitting around from a front cut I had years ago, they aren't damaged at all and decided to throw them on. 41580F8E-B3BF-4FF4-9969-68C1691B18AE.jpg That's a photo of the old ones showing how flogged out they were
A8D99E18-CF3A-497E-A3A1-37456936598E.jpg And the replacements now in the car :)
  • 1 month later...
Woke up this morning to the post man dropping something off and I ended up with this box
Was very happy cause I knew what was inside of it
B664247D-CCE5-442A-9B91-F8C545ADE0D4.jpg It's was my 2x3>3.5in midori front pipes and the final piece I needed for my new exhaust and after all this wait here is what I've gone with
It's midori front pipes, venom 3.5in 100cpi cat and a kakimoto 3.5in stainless cat back. Now being a typical Japanese exhaust the center muffler is actually only 3in, so I bought a magna flow muffler to replace it and ensure the whole exhaust it 3.5in
  • Like 5
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
