Been a bit slack the last couple of weeks but have been doing a lot of parts gathering IMG_4991.thumb.JPG.b403a9eed0b78edebb9ec2dbdba69302.JPGand here is the result of my collecting so far, after working out the fuel system wasn't going to be up to the job I decided to go all out
First thing to get fitted was the kit the tank hat belongs to
IMG_4998.thumb.JPG.bc8c290289b0a21eee1cf9ed223b25e0.JPGIt comes with a baffle to help prevent the fuel surge that's common in these cars
IMG_4999.thumb.JPG.7fddcc2619e8b91bf71ac52d50bc5c3a.JPGwith a bit of wiggling it slides into the tank and clips in where the original pump does
IMG_5001.thumb.JPG.a0be8caaaec23d3f9baf4f86f582435f.JPGand holds two walbro 450 pumps that will be staged IMG_5002.thumb.JPG.448feb2f67ae92984dac01fc19425027.JPGand the pump and hat assembly ready to go in to the tank, the kit also comes with a new sender for the gauge
that is an awesome setup....solves so many annoying problems.  are you happy with how will the new baffle/mount fits into the tank's original plastic holders to stop everything moving?
  • Like 1
There's is a little bit of movement once it's all clipped in but nothing to be concerned about, I had to remove it back out of the clip when I dropped a nut while installing it and there's no way it's coming out by itself
Speaking of the rail I fitted that yesterday IMG_4992.thumb.JPG.cc20d45fbc6f8442252bdca0b9142b5c.JPGbut first I fitted the new injectors which are a 1250cc with the stainless internals IMG_4993.thumb.JPG.3d5e8700427e6c3f1a1a1568b51f3956.JPGall 6 fitted into the rail and ready go into the car IMG_4994.thumb.JPG.d9cdc0294bc7d9641c627cfe96b108f4.JPGand fitted to the engine
Which also required a new fuel press regulatorIMG_4995.thumb.JPG.47f18ed9168164626879d5fb4819e180.JPGso I went with an ever reliable turbosmart one
IMG_4996.thumb.JPG.2c5a060bfcb50d50d9242c67dcda4531.JPGand mounted in the car, it was nice of Nissan to supply a bolt hole in the perfect spot
  • Like 1
Spent quite a bit of time over the last couple of days doing the fuel lines from front to back, it starts as a -8 from the tank and runs to the engine bay into the fuel filter, where it then splits into twin -6 and heads up to either end of the fuel railIMG_5076.thumb.JPG.3bdd561cb1ed8aa0eefd57cd3bb52a50.JPGIMG_5075.thumb.JPG.3ae8b07fc79e8e2ddffa83ce3ecff0ec.JPGthen comes out of the center of the rail to the pressure regulator IMG_5023.thumb.JPG.df50bdff7b0cdc10a6653532474b10ce.JPGI used the port where the pcv use to be for the vacuum signal and the original port for the pressure reg now only does the the map sensor
Had to trim a little bit to get the hoses on to the top hat and also ran all new wiring for the 2 fuel pumps and fuel gauge IMG_5033.thumb.JPG.74b3f74c7ca44f59c9e5b76fedf50b3f.JPGand after the cover was put back on with all the wiring tapped up it looks like it was done by Nissan IMG_5034.thumb.JPG.2532bf35c77255fa9e8fc9b2944d7e8a.JPG
  • Like 9
