Yesterday I got a call because my suspension parts had arrived 90712FF6-74DD-491A-91B8-F2409C4DEDE9.thumb.jpeg.bc4480686289bfa85450c5f4c3f3ee60.jpegso I have entire whiteline catalogue for the rear 1286FF73-CC92-4AE3-9459-DFE62A96363A.thumb.jpeg.5b1e94d040a74a2f27ad66840dc0b6d9.jpegand the front and rear sway bar kit also from whiteline
  • Like 1
And then I got a call from the other shop this morning and my diff was ready to pick up, I went down grabbed it and now it’s waiting till I do all the bushes and put it inC0F8EDDD-1F95-4002-A593-23CF0B24C5B7.thumb.jpeg.f3235c9e687ce026e0916e617ad7a13f.jpeg
  • Like 3
AD081CDE-0B19-4F6A-981E-2231019203AA.thumb.jpeg.d4f5b308e34e16ce6afb545976927e5f.jpegThe rear main seal was leaking so I replaced it with a genuine oneE165C02D-34E1-4003-8DB8-031AC3A6CC21.thumb.jpeg.8a18438c39a0c041955e87dd81cd663d.jpegCD28B5CF-7AC7-4A54-9D03-4A6AECC1668C.thumb.jpeg.657a6adfcf618bd84ed93762557fae99.jpegToday I got the clutch fitted 34845BA0-A66C-4DEF-A80E-5FB5F5DB681B.thumb.jpeg.4d78dfea4e2e3309faf495bc4440b2cc.jpegand the release bearing was a little noisey and I replaced it, I also replaced the spigot bush while I was in there
  • Like 1
Father in law just happened to drop in so I managed to get the box inA12F2937-D46C-4102-B6E4-44F02B5303A0.thumb.jpeg.d627739b172721738dff6bfcc8d31268.jpegI’ve got everything bolted in except the rear tail shaft because of the rear end still being out of it, I haven’t fitted the gearstick yet and I still need to bleed the atessa
  • Like 3
When you put in the 6sp Getrag did you have any issues putting the small dent in the tunnel to fit?
Did you take a picture of the location by any chance?
Edited by Anonymouse
Added a question
I saw the photos on rhd that nismo supplies and copied it, I think the rear would have cleared without it but would have been impossible to fill the transfer. I’ll take a photo when I get home
  • Thanks 1
  • 3 weeks later...
Have got all the bushes out and most of them back in, threw some paint over everything and it’s pretty much ready to be put back together 8BF689DA-36A5-4391-A0FA-579F6F18BB2A.thumb.jpeg.3a80f33dc6b04020fe7b4198994d7428.jpeg6906F43B-6446-419A-B5F8-7094A25FD169.thumb.jpeg.40f7158d8d5bb96030cb119b43b124f2.jpegA676F697-9A98-49C7-BEE0-2AE13EEAC067.thumb.jpeg.fc03922236b38344056592ba39791f03.jpegit’s all just good old pressure pack gloss black, hopefully can start assembling very soon cause o have under a week till roll racing
87C29BBD-6DD0-463E-98ED-78977B405D9B.thumb.jpeg.5974ae54b0639bebbc3d4adfd3b3c00a.jpegthen the lower control arms and set the sway bar to softC7DF6361-9C31-491A-A359-49712988B991.thumb.jpeg.bf6a41895df0ac3f261f1d8f01b4d11e.jpegthen the upper arms 061E80FE-7F9F-4319-BEA0-A9DB22F10FA5.thumb.jpeg.e68694ffb8de39c27593c1779bebff98.jpegthen the hubs and shafts and it’s ready to go back in, just have one other job before I can do that
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
