33 minutes ago, MBS206 said:
That's a very tidy exhaust job.
I like it!
Yeah, I know I won't weld that good if I attempt to do such work haha.
  • Like 1
When I told people my people my best mate was building the exhaust, most of them rolled their eyes. After I showed them the progress photos ive had a few of those people ask me to get a quote to build their exhausts
  • Like 2
Superbly neat welds!
I only wish I could weld that neatly, though that's the benefit of TIG, wayyyyyyy more control.
I'm a MIG boy, Ha ha, and my own is nastily setup as flux core which is worse! ?
Yeah I can only use mig, but haven’t had much of chance to play with a tig maybe after a bit of practice I could actually do alright
9 minutes ago, Robzilla32 said:
That looks like great work. A shame that most of it is hidden away. 4 inch or 3.5?
Yeah it is but the dump will be getting ceramic coated in clear so you will still be able to see it there. It’s a 4in
  • Like 1
3 hours ago, r32-25t said:
Yeah I can only use mig, but haven’t had much of chance to play with a tig maybe after a bit of practice I could actually do alright.
That's all it is mate, practice, practice, practice. I'm only as "good" as I am as I spent 40 hours a week on a MIG for 3 months straight. And by 40 hours, that's actual time on the MIG, not just at work.
And I'm not a good welder, I'm okay, not great. I have some inconsistencies. :(
TIG, just lots of hours of practice and critique.
I'd love to have a tig to actually do some alu work, but no money to buy a decent tig setup.
12 hours ago, Dose Pipe Sutututu said:
Fuuark, you're young inside. I've plumbed mine back lol.. but after the cat.
Should be good seeing your face once you open up your single #twinsaregay
I don’t have a cat to plumb them in after
On 16/08/2019 at 5:49 PM, r32-25t said:
It so quiet ? it’s perfect
Dumb q coming from me, how quiet is it compared to say HKS silent Hi-power?
It’s hard to say, it’s been a long time since I heard a hks exhaust. Its a lot quieter then my old 3.5in exhaust and easily quieter then most jasma exhausts
  • Like 1
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
