@WantGTR and I are both glad you threw the twin homos into the bin and became a man and went to a single. Response, power, transient, less heat, less hoses, less aids.
I still haven’t had the chance to really drive it properly because of different things and then when I got it working properly it tried to kill me and now I need to look into why
Toe the rear in about 2mm each side, so when it squats you'll end up with 0mm toe. Go more depending how much your arse end squats.
If you run traction rods, you can extend those and relax a bit on the toe in.
Also do you have a real rear diff? Or the lazy stock one?
I know this is a bad comparison, but back then when I was doing heaps of track work I was happily putting down 372kW at the rear wheels and the car would be straight every time and also on the street. Just good suspension setup and good alignment made all the difference.
It’s the stock diff that’s been rebuilt with nismo plates, it’s enough to feel it chatter on tight turns while accelerating but not enough to make it uncomfortable
wheel alignment is on the cards as are fresh tyres.
the 4wd is to slow at the moment, going to give it a bleed and see what happens
also looking at better quality coil overs
Set up has half the components which is great however not so sure about less heat. Everything on  the hot side is ceramic coated, braided hose with heat sleeve, even wrapped the dumo pipe over the ceramic  coat and put a heatsheild over rear housing. Gets pretty hot under there.
  • Like 1
The only thing I’m really concerned with is the turbine housing which was supposed to have a beanie and will still be getting one, everything else has been has plenty of gap and won’t be a problem
  • 4 weeks later...
Big change.
A radiator air guide thingamagig does wonders for cleaning up the front and hiding the thermos and stuff, I'm dubious if it actually helps with cooling though.
Plus it's a good work station for tools and stuff.
  • Like 1
Bleeding the 4wd seems to have helped a lot, you can still feel the back moving around but it doesn’t snap oversteer any more, will still be something I work on more.
once doing that it then brought the engine protection on again meaning even with 6L of oil the standard sump is useless
10 minutes ago, Count Grantleyish said:
Snapchat it.
This one I have but you wouldn’t be able to hear it
1 minute ago, Dose Pipe Sutututu said:
It's 2020, Tik Tok it
this one I don’t
  • 3 weeks later...
Been a slow with the updates, finally decided to dig into the boxes I posted a few pages back
here’s the old b/c pillar trim in the carA26DCC92-5C83-40C6-B772-862E2AB1F60D.thumb.jpeg.71cc5fdd00139376a9a86803b51c6a84.jpeg old and new beside each other, the old ones weren’t the worst I’ve ever seen F26C7294-8FD6-474D-B667-A69ECF728B78.thumb.jpeg.d3027a681410e0c6035b78611e244b5c.jpegand new one installed in the car BA798E42-5BC9-43D6-B9BD-9B315BDE788C.thumb.jpeg.60824859848f0af97cca32bc39c8c5f4.jpeg
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
