1 minute ago, Robzilla32 said:
More that I was asking about the engine pushing water.
Oh last time I went roll racing the engine lifted the head and started pushing water out the over flow on boost
Adam is a gun, you’re in good hands. PPG does not have provisions for reverse lights so they won’t work. You still have the switch on the outside of the box, but there’s nothing internally to trigger it.
this is what I was told, after the PPG was fitted! Lol
You will be amazed how fast it shifts compared to a synchro box.
I trust Adam and he’s kind of close to home which is great.
There’s no external switch on mine but on the gear indicator box there’s a wire marked reverse light +ve and I’m assuming that triggers the reverse lights,
I drove it on the jack stands to make sure all the gears were there and the neutral lock was working correctly. Guess is should pull it off the stands
  • 4 weeks later...
Decided to go through all the boxes today57976720-8CE8-4D4A-B278-819093AE5FEA.thumb.jpeg.09051f5802bb1eb5b9e4155ecd803127.jpegsprings
4AC4FB91-8B16-40B7-9299-89332E6CE230.thumb.jpeg.a12181f586dd02e87bd52126d75bdc55.jpegover sized valves
2F62A64E-8951-4B25-AE3F-22FCEEF2CC29.thumb.jpeg.230fb03ef2b1cd24be722bce4d1e0e2c.jpegbuckets
88C29FA2-206E-4CCB-AA97-E9A958512EFF.thumb.jpeg.cc91747c45269dea57a71f8ae3fcb831.jpegguides and locks
1DFCBA5F-608C-4143-B706-274CBA1B0929.thumb.jpeg.56b57e04c7f260e1bf865c306998c97f.jpegand cam cap studs
basically everything needed to make the head better then new
  • Like 1
53 minutes ago, Old man 32 GTR said:
What cams are you using?
I’m in 2 minds on what I want to do for the cams, mainly revolving around weather to keep the vcam or not
It’s definitely seen that way and does add plenty of low down torque and response, but if I’m going to do this much to the head and etc, do I take full advantage of the extra flow and get some cams in there with plenty of lift?
Yeah, tough decision, but if you got it, probably best to stick with the V cam? If you want more flow, strap a bigger turbo to it 😁👍🏼
  • Like 1
I did have someone recommend a 6870 but the 6466 is lots of fun and still has a lot more to give
64/66 is perfect, with the V cam would be quite responsive as well, perfect set up, just fix the head and turn it up!
what power did you last make?
I can get you a drive in a GTR with a 64/66 turned all the way up and backed by a PPG sequential if you want an idea of what it’s capable of. Just shoot me a pm if you’re interested.
  • Like 1
It made 465 at 27psi according to the dyno sheet but the run finished at 6,600rpm due to a cooler hose popping so would be making a bit more at 8,000.
id be keen on that, I’ll flick you a pm by this afternoon
Regrind the vcam? Best of both worlds
  • Like 2
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
