The sensor grounds all go back to the ecu and none of them are on the battery ground, Adam suggest putting the flex sensor straight to earth because of it being a frequency signal can play with the others
it does it on the road now that I’ve driven it and paid attention, not sure if it’s rpm or load making it happen though
One of the issues Adam mentioned was the tail shaft center bearing being flogged out, I took the shaft down to be rebuilt after a conversation with the owner of the shop it was decided a whole new shaft was the best way to go.
so after taking measurements and waiting a week my new shaft was ready to pick up
 IMG_1502.thumb.jpeg.9a059e71280a53246a59242b861b9e29.jpegIMG_1505.thumb.jpeg.20458f2f09668823c93cddfc2f7c6efe.jpegIMG_1503.thumb.jpeg.6c2c3a3ac64e22ea38374761253227d9.jpeg
new and old shafts next to each other, yes the new one piece shaft and was worried about vibration, after driving the car turns out that there is nothing to worry about
The only requirements/issue with one piece tail shafts is tail shaft RPM, the length of it, the diameter of it,  the pinion angle, and material used
Daily driving at 110 kph it top gear with a one piece will probably never see any harmonic issues at ???? tail shaft RPM, but, at 200kph you might see some harmonic issues if your tail shaft isn't spec'd right
I looked into this alot when I was looking at a new tail shaft for my VX SS after it constantly flogged out centre bearings and getting vibration over 160kph, in saying this my "pinion" angle from the gearbox to the centre bearing was the issue, slightly to much angle caused the centre bearing to flog out from harmonic vibration at high tail shaft RPM, but for me the issue was the 12mm lower engine mounts, after getting the angle of the dangle from the transmission to the centre bearing lined up correctly, and to within spec (OEM height poly mounts), the car is happy at 200 kph (125mph at the drags) now even with the OEM spec centre bearing and rebuilt OEM 2 piece tail shaft
What's your tail shaft specs?
  • Like 2
Approx 1m long, chrome moly, hardy splicer unis. Didn’t measure the diameter. The shop that built it also builds the shafts for b2r, jem, maatouks, etc and built the shaft to the same specs as their cars that’s are running 7 and 8 second passes!! Which say to me that it can handle some big mph
  • Like 1
It also depends on gearbox ratio.
Those drag cars running 7s passes aren't doing it on an overdrive gear ratio (probably). 1:1 is "fine", the critical RPM for a 50' single driveshaft in chromemoly is 6900rpm....
....but when you shift into 5th and use 0:73 or 0:8 it all changes. Do you know their rear diff ratio? etc.
That's the stuff that matters with regards to it. Whether it actually matters given your use application is also relevent. You may never get into those scenarios, like most ruined GTR's from Western Sydney don't :p
  • Haha 1
2 hours ago, Kinkstaah said:
You may never get into those scenarios, like most ruined GTR's from Western Sydney don't 😛
they might see those prop shaft speeds for 1 to 2 secs only
With same diff ratio, tyre diameter and road speed, the tailshaft rpm is the same regardless of the gearbag's ratio. Given that very quick drag cars are probably doing similar road speeds to the fastest circuit cars (circa 300 km/h), and there will be many of either category that can't go that fast and so you'd have inummerable matchups between drag and circuit car speeds at smaller numbers, and given that they are probably using rather similar tyre diameters and probably using similar diff ratios, and...where any of those numbers were different they could quite easily be in opposite directions thus cancelling out....
I think you'd find that there'd be more similarity than difference in tailshaft speed between these two use cases, no?
Shaft speed would be the same, however it's how long they hold it there for and repeated conditions.
FWIW half way down the main straight at SMSP I'm bouncing off 4th with a 8600RPM limiter. That shaft would be spinning at 8600RPM for a few seconds before I need to smash the brakes, by T2 it's getting close to that speed again. Now a drag car/roll race car would see that shaft speed for a 1 to 2 secs then they would coast, hit the brakes and that's it.
Oh, yeah, no arguing that the duty cycle is different. And a circuit car will go to those speeds for more distance and longer times. But, I suspect that if a tailshaft has a harmonic problem, that it would cause damage and shit itself maybe even on the first pass. A second or two of running at the resonant/harmonic problem speed is already a couple hundred revolutions.
7 hours ago, GTSBoy said:
And over it. Need to stop it coming through the floor.
From videos and photos of them coming apart, I'd be adding a loop near the front of the shaft too.
Have seen the remains where it has let go, been caught by the centre loop, but shaft is happy to bend about 90degrees at that point and proceed to slap the shit out of everything as it dies a catastrophic death.
Just now, GTSBoy said:
It's a race to the death between the oil pressure and the fuel pressure (from the tailshaft spreading the fuel line out across the underside of the car).
I am actually chuckling about that out loud!
Sorry, I confused myself here. I meant it would hit critical RPM at the kind of speeds where engaging 5th in most skylines is a possibility. Rear diff ratio matters tho.
But yeah if people are trapping 150mph+ then... their driveline is likely already tinkered with...
I just feel a tailshaft pole vault is not something anyone wants to run the risk of/test when they know the numbers. It may be entirely fine and overblown as a risk...
2 hours ago, Dose Pipe Sutututu said:
Brutal cnuts 😂
Brett's car has a dry sump thing though
Dry sump? Is that like where you don't put oil in, and leave the car parked in the garage because it's worth so much now and is like a beautiful museum piece? 😛
  • Haha 1
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
