We replaced the connector just because we could and it was still there, once we swapped the injectors around it stopped. The injectors were something I had thoughts of replacing even before I first started the engine and in hindsight I should have
  • Like 1
  • 1 month later...
Haven’t had a chance to drive it properly yet. It was rwd and pissing down rain when I drove it home and now it’s in the air with the so I can change the oil. Going to do the  gearbox oil while I’m at it as well, may even do the diffs
1 hour ago, admS15 said:
Pretty stout result. How much boost? Anything left in it?
It’s at 30psi, there’s still plenty left in it and Adam said it was making the power easily!! We ran out of injector though
Post it up on YouTube and a non public video and dump the link back here, it embeds it.
Imagine you have a Borg Warner turbo, you'll probably end up driving home without boost 😆
I kid I kid....
I kid I kid....
Does it not work?
It works but you have to download it, save it somewhere, open it from app of choice.
Also it sounds awesome. I went back 50 pages to see what gearbox was in it. During this I saw a lot of memes about going to All Japan Day, whatever that is. I'm pretty happy to see you finally made it with no issues as I am sure you are too!! :91_thumbsup:
  • Like 1
Did you find out what gearbox is in it?
As after seeing the video I'm curious.
If he's gone all Samsonas, then I want to know when the new injectors arrive...
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
