We replaced the connector just because we could and it was still there, once we swapped the injectors around it stopped. The injectors were something I had thoughts of replacing even before I first started the engine and in hindsight I should have
  • Like 1
  • 1 month later...
Haven’t had a chance to drive it properly yet. It was rwd and pissing down rain when I drove it home and now it’s in the air with the so I can change the oil. Going to do the  gearbox oil while I’m at it as well, may even do the diffs
1 hour ago, admS15 said:
Pretty stout result. How much boost? Anything left in it?
It’s at 30psi, there’s still plenty left in it and Adam said it was making the power easily!! We ran out of injector though
Post it up on YouTube and a non public video and dump the link back here, it embeds it.
Imagine you have a Borg Warner turbo, you'll probably end up driving home without boost 😆
I kid I kid....
I kid I kid....
Does it not work?
It works but you have to download it, save it somewhere, open it from app of choice.
Also it sounds awesome. I went back 50 pages to see what gearbox was in it. During this I saw a lot of memes about going to All Japan Day, whatever that is. I'm pretty happy to see you finally made it with no issues as I am sure you are too!! :91_thumbsup:
  • Like 1
Did you find out what gearbox is in it?
As after seeing the video I'm curious.
If he's gone all Samsonas, then I want to know when the new injectors arrive...
    • The final part arrived today to un-clampify and simplify the intake Who would have though a 1/2" hose stainless bulkhead fitting designed for below waterline bilge pumps would be what I needed Test fit on a 3" offcut I had laying around to see if it would work, and it worked a treat All going well the intake will be on its "final version" tomorrow
