Pressure tested it today and found a hairline crack about 1/4 inch long on 1 intercooler pipe. Can't put a silicone joiner over it in the interim because whoever made the pipe, squashed that particular piece to an oval shape so it won't seal. Found 2 others leaks, 1 was the idle adjustment screw and the other was the bov but that's out of a factory hole cast into the vavle.
Replaced cracked intercooler pipe, problem is miles better but still exists. Only on boost and only in low boost range. Once it gets 4-5psi in its guts it clears up and revs like normal. Get an occasional backfire as it's trying to build boost.
Car was tuned in Feb and hasn't faulted since, pretty certain leak was a new problem. It reared it's ugly head after having a boost spike of 6-8psi briefly while setting up a boost controller. I'll try some known good condition coil packs.
Edited by fmlycar
As in, car was tuned, then you put in a boost controller, and it overbooosted then misfire started.
That's kinda bad.
Yeah it over shot and I backed off as soon as I seen it going past where it should be.
Just pressure tested again and found a line teed off from the boost guage line was leaking slightly. Have fixed that. Went for a drive and hasn't made much difference. Only other leak is out a small hole cast into the bov but that can probably be ruled out if it's always been there.
Car was tuned to 18psi. Ebc is in preparation for another turbo upgrade so I can run a couple boost settings. Everything suggests healthy motor, and tune was very safe as that's what I wanted. Knock never goes any higher than 30 at any given time but is for the most part under 20. Tool it for a high speed run last month and never went above 18 in all gears right up to 6500rpm in 5th
Edited by fmlycar
Took cas off, removed cover surrounding plug and sprayed inside as best I could with circuit board and contact cleaner. Reinstalled and set timing. Has now moved the misfire to more than 1 bar of boost and cleared up down low. does this sound like I should replace it?
Did you rest your timing and a small thing but 15 degrees at 650rpm for a gts25t??? That is not the orange line - each line is 10 degrees.
Mind you, I don't think thats the problem but just to be sure.
Isn't it 20 degrees btdc for series 2? I did 15 to begin with and ran like a complete bag of poo, then set it for 20 and was loads better, but not perfect. I'll check tps values again just to be sure and try borrow a working cas to see if that's it
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
