Agario is so frustrating!
Oh shit son I'm so massive, haha fk I can eat anyone, oh f**k, what the f**k is that...split...game over.
Even just starting off and it being so uncontrollably fast that you just waltz into another cell.
But man is it a good time killer when you're waiting for something or bored in bed.
  • Like 2
I don't see much difference. I've seen plenty of staff quit using SMS too so I mean if it's good for the goose..
this is generally regulated by the Fairwork Act if there isn't an employment contract in place
Under the Fairwork Act employees don't even need to give written notice to quit or resign they can say verbally
So using a text to quit is sufficient
Sadly the same can't be said fir employers who must provide written notice for termination
f**k the numbers game, it's what makes most management so f**king useless. Many don't care who/what/when/how, just the dollar sign.
I would have thought statisticians and market research companies did all the hard yards for big business...
This is my point it should be fair for all I don't think employees should be able to use SMS and neither should employers.
They'll need the written notice for their centrelink benefits...
Besides probably being more expensive (unless you go offshore), a potential problem with outsourcing your data analysis is not always being able to relate it to products/services/outcomes unique to your business model and translate in terms your managers and employees will understand and make decisions on. Even if you achieve this, it's still a costly back and forth that could happen within the one person's brain.
If they can get marketing coordinator and data analyst in one, they're combining two roles and cutting out the Chinese whispers of a middle man. Still, it sounded like a pretty specialised role - I have no doubts they're earning their 200k.
I think in a similar manner, I outsource copywriters to write me articles for publications but sometimes they just don't use the language that you use to achieve homogeneity across all company documents, or know what's important to hone in on. Sometimes that takes years of surrounding oneself in the company culture to pick up on, a benefit outsourcing really misses out on unless they've been around for years and years. Sometimes I just write the shit myself so that it's on point first go lol
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
