Dezz phillip island on the bike awesome fun, crazy speeds when you're going around a corner and look down at the speedo
Did miss not having a front windscreen though, 'sports' bike clearly more ideal for that sort of thing..
Top speed on straight?
Best lap?
They don't release lap times so dunno.
About 230 on the straight when I looked down, I coulda gone bit quicker probably but think my bike maxes out about 250 on the gearing so by then it was revving titties off - not to mention getting hit in the face by all the wind (I actually had to change helmet cos mine was pushing into my face and was hurting baddd) time for a new helmet I think.
Edited by UNR33L
Helmet sounds a tad loose? Though that could just be having no wind deflector?
As for laptimes get a GPS app for track days!
Pumped for PI later this year in the car.
yeah i didn't mind they wern't timed, people were coming off left right center
I had a moment at t1 were i hit something plastic on the track.. probably off someones bike
helmet has been gradually been getting worst, probably just worn out on the inside and became bit loose
Edited by UNR33L
Yeah I think the rest of that session I was a bit slower / more cautious..
Tyre got nice and melted, was really choppy until I turned the rear suspension a bit stiffer then smoothed out, wish my pegs were bit higher up or further back for the track though :P
Edited by UNR33L
i'm not sure, i only saw the aftermath of them standing in kitty litter wondering why they just scratched up their bikes
I saw 2 in my sessions, but i'm sure there was a lot more that I didn't see or other groups (one was at turn 2 so that would of been pretty quick)
Edited by UNR33L
So.... Turnbull quitting Communications Minister and gonna challenge Tony for PM...
I'm guessing there will be some sort of Budgie Smuggler competition to see who wins, since I don't think either of them would be able to throw or take a punch very well... And jousting is out... Something about OH&S issues and CFMEU got involved
Bought some Asics Kayano Evo today (so f**king melbourne wanker) holy shit these things are absolutely streets ahead of nike. I think a 25 year relationship is about to be tested...
Great shoe.
Shame they look like shit
Warren Truss may have saved Abbott's skin here.... which is highly depressing... not because of Abbott but the thought of those scumbag redneck Nationals having the power to decide on our leader based on their Cletus Spuckler views :/
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
