Don't think upper Lower class bogan eats at fat duck.
see that's it, we eat and travel well, but I drive a clapped out Falcon ute....just to confuse people.
Hell that meal was probably as much as the ute worth!
That said on the food front:
tried Brae a few weeks ago....such a rip off of fat Duck and food was horrid.
plus ultra stingy with the paired wines. almost make FD seem reasonable.
You travel for work, paid for by work. You're not Dan Bilzerian
all these meals are what I pay for however and around melb so not on work trips.
Work would freak if I expenses a 500$ + meal per person.
gotta keep it to under $100 a day for expenses, but when you traveling to south east asia means you live like a king for $20.
yeah it ranked as no2 in vic and the chef won heaps of awards.
but it like he trying to do recipes to shock ppl not to taste good.
Oyster ice cream
final dessert was stewed rhubarb coated with crumbed pistachio and a little cranberry jam...plus Blood, ffs what is that mean to add to the recipe?
smoked peaking duck breast that was almost impossible to cut let alone chew.
went to supper inn in the CBD the next day and so much better. and for the price of one persons drinks the day b4.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
