VW golfs are the new civics it seems... Saw 2 golfs at different times, 4 dudes in it hanging out the Windows yelling at people, covered in stickers, dumped, loud exhaust, DSG and obnoxious amounts of dose/flutter. One was GTI the other TDI.
I had that with a bunch of wogs in one hanging out the windows
Apparently their car had nos but that and the overt homosexuality of 4 guys in a VW was no match for E85
There are 2 options:
1. Connect with young people and obtain votes.
2. Do not connect with young people and hope your economic policies will get you elected, which let's face it, is not what young people vote on.
  • Like 1
You either die a politician with viable economic policy or tweet long enough to see yourself become the greenie for young social justice warriors
So my mate is wearing these today :0
What
Tha
f**k
Those sites are a joke
I googled a pair of $99 5s I bought off catch of the day 3 years ago and haven't worn once...apparently now worth $400+ if you believe those websites
Also who the fk buys online guessing their sizing like that for $8000 shoes lol
Kind of person that pays $8k for Jordan 5"s would have 50 pairs and know his size dude
Kind of person who pays $8k for a pair of shoes is a f**king retard and I'm guessing would accidentally select the wrong size due to lack of dexterity in the fingers
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
