Science v religion going off in the grind my gears thread
Now featuring a guy who believes that science...er...proves the theory of evolution to be...wrong?
Pretty sure the guy may be Ken M
I re-read and it actually never said hp or kw so that's my bad. He said stock turbo at first then later said he was using an eBay special, so who knows.
I've been helping a friend of mine for well over a 2-3 years regarding pulsar questions and opinions... I've tried to help him with so many things, get quotes for engine work, recommended mods, what he should do etc. At least one question a week. Went and bought an ok S15 for when he is off his p's, but still happy to spend money on cosmetic bits for the pulsar, planning for engine bay bits later (half of which he was going to buy off me). Now he wants to sell the pulsar with all mods attached at a loss, sell the S15 and get a MK5 R23 golf. FFS. I should have given up on him long ago. f**kin dream boats just go with the times. I should have known from the flatbrim, I just thought it was kids these days.
Stop being the fence sitter about Chequered. Aint nobody say HP in fact it says KW.
Seriously, my reply was too complicated for you?
No one said it was a Chequered customer, that was just Birds trolling.
I was simply stating the dude might have got mixed up as 210rwkw is not too far off the mark.
I'm riling u up bish cos we all know u kick off about Cheqqy
at no point you didn't think perhaps he was trolling ya I mean who really wants to mod a pulsar anyway?
  • Like 1
he's a nice guy and i met him through pulsar meets... he spent big money on 90mm sleeves and pistons to go 2.2L... but has been talking about doing it for over 12 months. i even got quotes for him to do it.
i always stress to anyone thinking about modifying to consider goals/budget etc plus if you plan to keep the car. if you think your own car isnt worth fixing up... get a better one and swap the best bits over.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
